Window question
Window question
my window crank on my 1965 convertible is off center and rubs against my door panel if not careful when you crank the handle to move the window up ir down - the spline is off center. Which parts do I need to replace? I checked the vendors and cannot identify the parts I need to buy. Any help appreciated. Thanks.
Received 2,127 Likes
Is your door panel mounted tight to the door via the lag screws under the arm rest? Do you have the spacer and the plastic washer? Is the regulator secure. Could it be bent causing the misalignment. Dennis
