Windshield Washer Fluid
Old Jun 4, 2017 | 05:25 PM
66VetteStingRay's Avatar
66VetteStingRay
Default Windshield Washer Fluid
I have a windshield washer bag on my 66 Coupe. Any advice on what wiper fluid to use? I wasn't sure if all available windshield washer fluids were safe to use in this bag and on this type/age of car.
Old Jun 4, 2017 | 05:41 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Unless your getting it judged the next day why in the world would you put fluid in the bag?
Old Jun 4, 2017 | 05:58 PM
66VetteStingRay
I don't have an immediate use for washer fluid. I was just wondering if and when I decided to put fluid into the bag, if anyone had recommendations for a particular type/brand of fluid to use. There are many varieties of washer fluids on the market with wide range of ingredients/additives and I just wanted some input on which ones to use/not use. That's it.
Old Jun 4, 2017 | 05:59 PM
Nowhere Man
If you think what ever use is going to work you have anything coming. But if I was to try just the old fashion blue type will work
Old Jun 4, 2017 | 06:08 PM
66VetteStingRay
Thanks for the recommendation.
Old Jun 4, 2017 | 06:10 PM
Nowhere Man
Word to the wise I would remove the bag from the car and fill it up and make sure it holds fluid for a few weeks. So if it leaks out it leaks not in the car
Powershift's Avatar
Powershift
I would probably use distilled water...........and call it a day. About $1 a gallon.
Empty the bag during the winter months or run a bit of the blue stuff with methanol thru it at that time to keep from freezing. Distilled water will leave no water spots if/when used.
Larry
Old Jun 4, 2017 | 06:13 PM
66VetteStingRay
Larry
I was thinking of just using water but distilled water makes more sense. Thanks, Larry. I appreciate your reply and advice.
Old Jun 4, 2017 | 06:40 PM
66VetteStingRay
Great advice. Thank you.
Old Jun 4, 2017 | 08:01 PM
SI67's Avatar
SI67
Whatever you use in your other car or cars, if any, will be fine.
Old Jun 4, 2017 | 08:15 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Larry
Distilled water is the only thing the late Tom Maxwell recommended for C1 washer systems. Prob applies to C2s as well.
Old Jun 4, 2017 | 09:28 PM
66VetteStingRay
Thanks.
Old Jun 4, 2017 | 09:29 PM
66VetteStingRay
Sounds good. Thanks. I'll use distilled water when/if necessary. Thanks again!
Old Jun 4, 2017 | 09:43 PM
ricks327's Avatar
ricks327
When we install a new plastic water bottle/jug, we leave it empty unless going for NCRS judging. Then we put water in the jug and tell the owner to make sure to empty it before winter and to clear the pump and lines. The color stuff will discolor the milky color plastic jug. Obviously this is somewhat different than the bag, which I have no experience with.
Old Jun 4, 2017 | 10:23 PM
Gary's '66's Avatar
Gary's '66
I use RainX in mine, even though I've only been in the rain a couple of times.
Gary
Old Jun 4, 2017 | 11:13 PM
66VetteStingRay
Thanks. I appreciate the info.
Old Jun 4, 2017 | 11:17 PM
66VetteStingRay
Gary
Thanks, Gary. I appreciate you letting me know what you use.
To Windshield Washer Fluid
Old Jun 5, 2017 | 07:03 AM
R66's Avatar
R66
Curious,
when did Chevy use a bag vs the plastic jug? R66 (born 12/65) has a plastic jug.
Old Jun 5, 2017 | 09:18 AM
Nowhere Man
Originally Posted by R66
Curious,
Only factory AC cars and 65 396 cars got the bag. Or cars with the battery on the drivers side
Old Jun 5, 2017 | 09:47 AM
Jackfit's Avatar
Jackfit
Default To clean my windshield!
Same reason they put fluid in it 50 years ago..lol
