[C2] brake question
Old Jun 7, 2017 | 09:45 PM
candipogo's Avatar
candipogo
Default brake question
I have a 64 roadster. are the brake pedal swing arms different for power brake cars and non power brake cars? mine has disc/drum, dual master cylinder conversion. manual set up. still has power brake pedal assembly. car stops fine, but pedal is hard to push. just wondered if the manual swing arm was a different pitch or length.
thanks, phil
Old Jun 7, 2017 | 09:51 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
There are two holes for the clevis in the brake pedal downrod. The lower hole is for power brakes, the upper for manual. A power brake master cylinder is tilted so the lower hole is required, it also compensates for the reduced pedal effort to operate.
