injection cable
Old Dec 11, 2020 | 02:12 PM
silver837's Avatar
silver837
Are you talking about the cable inside the sheath ,or the whole assembly ?
You should start your own thread as this one is 3 years old. Include the year of the car and model of the FI unit to help the people who know .
Welcome to the forum
Old Dec 11, 2020 | 02:49 PM
MikeM's Avatar
MikeM
Originally Posted by Jim Trucksis
Can any of you refer me to documentation on how to replace the cable? I'd like to make sure I don't create 2 problems when trying to solve 1.
Thanks!
I take the bare cable and insert it into the pump, then align it with the distributor gear. Remove it, stick the cable in the sheath and then into the pump. Then, just stick the cable square end into the distributor. It should already be lined up.
Old Dec 11, 2020 | 03:12 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Also, slather more grease on the full length of the cable than you think is reasonable. Your guiding principle should be that too much is not enough.
I use and recommend wheel bearing grease.
Old Dec 11, 2020 | 03:24 PM
jim lockwood
Thanks!
Do you know how to remove the old cable?
Old Dec 11, 2020 | 04:12 PM
Jim Trucksis's Avatar
Jim Trucksis
Cruising
Thank you for the welcome and the good advice.
Yes, I'm talking about the cable inside the sheath. I can unscrew the sheath end at the distributor but wanted to make sure I did the right process at the injector side. Hence the request for some direction on the procedure.
Old Dec 11, 2020 | 04:36 PM
jim lockwood
Once you unscrew the nut at the distributor end of the cable housing, push the cable housing forward into the high pressure pump. It will move about 1/2".
With your finger tips, grasp the flange on the cable inside the housing and move it forward into the high pressure pump. Once you push it far enough, the end of the cable will clear the shaft in the distributor
Swing the cable and housing away from the distributor.
Grab the housing and pull it to the rear, out of the high pressure pump.
That's all there is to it.
Old Dec 11, 2020 | 08:46 PM
Jim Trucksis
Cruising
Super! Even I can handle that one.
Thanks again and Merry Christmas
Old Dec 12, 2020 | 12:15 AM
silver837's Avatar
silver837
Listen to Jim Lockwood !!! He knows Rochester Fi like "few" others.
Old Dec 12, 2020 | 10:08 AM
Jim Trucksis
Cruising
Thank you and I will. I'm excited about being part of such a passionate and knowledgeable community.
Merry Christmas!
Old Dec 13, 2020 | 11:13 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I have nothing to add.
Old Dec 13, 2020 | 02:13 PM
silver837's Avatar
silver837
Jim
DZAUTO is another great resource for FI repair and knowledge. Listen to him also.
Old Dec 13, 2020 | 09:40 PM
OC-1's Avatar
OC-1
2500 rpm with a naked cable on the 63
JD
Old Dec 13, 2020 | 10:32 PM
  #33
jim lockwood
JD
Put your engine under a heavy load, like wide open throttle acceleration, and your cable will resemble the one pictured in posting #13.
I guarantee it.
Old Dec 14, 2020 | 07:42 AM
  #34
MikeM's Avatar
MikeM
I guarantee it.
If it's an OEM cable, I'd double guarantee it. I can show a twin to it for the same reason.
Old Dec 14, 2020 | 09:23 AM
  #35
OC-1's Avatar
OC-1
posted just to illustrate cable running car at normal speed, as in roadside cable replacement, sans housing, will be fine to get you home.
Old Dec 14, 2020 | 09:41 AM
  #36
jim lockwood
Even more than that. As long as you aren't a lead foot, you can drive for a long time with a bare cable. Just don't do wide open throttle and expect the cable to be happy about it.
Disclosure: Because I R&R FI units on my car pretty often, I never install the cable in the casing. Doing so would slow down my work.
