Have you checked the fluid level? When the trans-mission fluid is low in my '54 (usually because the car sat for a while and the trans puked) the transmission will do odd things.
Jim
Reason: eliminate sneaky, auto-inserted link
Thanks Jim. The fluids level is fine and the fluid was changed a few months back.
Had the car for a few years and never noticed anything until we went for a ride in the wine country. On some back county roads in some step hills tried to use low to slow down and nothing.
If Roy Bratz would log on once in a while he used to work on them and actually made a rebuild video.
I ended up taking my cast iron '54 Powerglide to an old school guy who knows the tricks to make them run like they should have from the beginning. Since I had mine done it doesn't leak, doesn't puke (I leave it in park for months at a time) and works perfect.
