[C2] Add power brakes to 1967 Corvette
I'm reviving this thread because I'm currently doing this conversion on my '67. Regarding the hammering out of the firewall studs in order to mount the booster, has anyone just hammered out the studs on the booster instead and then just used the existing firewall studs to mount it? The threads appear the same and it seems like this would be easier and then the nuts would be more easily accessible.
Received 2,333 Likes
I just did that two weeks ago by hammering the studs from the firewall. The studs are a friction fit and came out with just a few medium taps. The studs from the booster fit into the holes and bolted right up. Not an issue at all.
Good Morning,
I now have all the components installed except for the brake line fitting at the front, which I'm struggling with to get lined up. I've been fiddling with it for an hour with no luck. It's close but I just can't get it to line up. I have a Borgeson power steering unit in which I'm not sure if it makes things tighter under there or not. Do I need to just loosen the steering box in order to gain enough clearance. If you guys have any tips, I'd appreciate it.
Rob
Rob
