Adjustable temp sensor
Old Jul 8, 2017 | 06:40 PM
rgbau140's Avatar
rgbau140
Default Adjustable temp sensor
Long Island has an adjustable resistor for sending unit. 22-17c
Has anyone tried one?
Old Jul 8, 2017 | 10:06 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Yes I have one on my 57. An accurate sender in like trying to find a unicorn. It's basically a resistor that sets the temp gauge at a known temp. I set mine at 170 degrees from taking a reading on the water neck with a temperature gun. I believe the reading is only good for the temp you set on the gauge. Mine works great.
Old Jul 8, 2017 | 11:23 PM
rgbau140's Avatar
rgbau140
Where did you wire it in? The write up for the unit talks about wiring it in under the dash
Old Jul 9, 2017 | 08:41 AM
Geralds57's Avatar
Geralds57
Yep, that's what I did. Easy access to the tiny adjustment screw on the unit.
Old Aug 1, 2017 | 11:54 AM
rgbau140's Avatar
rgbau140
Does the unit need to be near the temp gauge? Access is difficult on a C2 - the temp gauge is above the ignition switch. It would be much easier to wire it in under the hood
Old Aug 1, 2017 | 12:56 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
If its wired as a simple "series-connected" rheostat it could go in the temp sender wire from the unit wherever is convenient... Somebody would have to verify.
Interestingly - this is the same fix the factory came up with for the inaccurate temp sender reading on my Sea Ray boat...calibrated for accuracy at 170*..
Old Aug 1, 2017 | 01:58 PM
rgbau140's Avatar
rgbau140
I saw nothing magic about wiring it in under the dash, other than to hide it from detection. But I have been wrong before about stuff I didn't think mattered. Lots of time on this forum alone
Old Aug 1, 2017 | 02:21 PM
Mr D.'s Avatar
Mr D.
Adjustable temp sensor, guess that's one way to ensure your engine doesn't run hot.
To Adjustable temp sensor
