tire help
Old Jul 10, 2017 | 11:20 AM
old68's Avatar
old68
Default tire help
I know there are some older posts, but the availability keeps shrinking on tires,
can anyone recommend 205 75 15 tires??
what about 215 75 15 or 215 70 15 wil they rub on the body at all?? are they the same height more or less??
thanks a bunch my cokers are 7 yrs old and making me nervous , no way I'm gonna spend 250 a tire again, heard some negatives on the quality of cokers.
thanks a bunch , any hep would be great!!!
Old Jul 10, 2017 | 12:09 PM
leif.anderson93's Avatar
leif.anderson93
blackwalls, whitewalls, redline, goldline...kinda need to know.
Old Jul 10, 2017 | 12:23 PM
Gary's '66's Avatar
Gary's '66
I have 215/R70/15's on two different types of rims (bolt on KO's and TT II's) and neither rub.
As to tire selection. You say there's no way that you're going to spend $250.00 a tire again and, you don't have to.
That said, you can easily find a set of Toyo's or, a comparable brand, for around $100.00-$125.00 each. Have you checked out the Tire Rack?
On the other side of the coin, if you're looking for a stock looking tire (I say this since you mentioned you now have Coker's) you'll need to pony up the dough.
If you do decide on a stock type tire most here, myself included, will vouch for the Michelin Diamond Back! Unfortunately they're about the same cost as the cokers but, of MUCH better quality.
The old saying of "you can't have your cake and, eat it too" pretty much sums it up.
Gary
Old Jul 10, 2017 | 12:38 PM
tomy62's Avatar
tomy62
St. Jude Donor '17
You may have read this before on the forum but Diamondbacks are the way to go in whatever size you choose. The 205 is the closest to the old 6.70-15 bias ply although it is ever so slightly shorter. About a quarter inch as I recall. I am running the 215/75-15 black walls from Diamondback and am very pleased. I went with the 215 size as the wheels are 5.5 inch wide and the st12 references that as an option although not as an rpo. The 215 is about a quarter inch taller
than the 6.70 was/is. Specifically, it lists 7.10 and one more size up from that (I forget now). No clearance. or rubbing issues at all with the 215/75 size although I have no experience with 70 series on the car.
Old Jul 10, 2017 | 12:53 PM
old68's Avatar
old68
Default sorry
sorry, my bad, i am 65 roadster. looking for blackwall or whitewall or raised white letter, thanks again
Old Jul 10, 2017 | 01:09 PM
R66's Avatar
R66
I put on Hankook H724 radials P205R75-15. They have about a 5/8" wide whitewall.
Only have about 1500 miles on them, but they have been good so far. Less than $300 for 4, less than $400 mounted and balanced. They balanced very well with little weight. No problem with fit under the fender wells.
I couldn't see spending a lot of money for a driver that only gets 1500 miles a year on it.
Down side is they are not made in the USA.
Old Jul 10, 2017 | 01:16 PM
old68's Avatar
old68
Default anybody have these?
Amazon Amazon
Old Jul 10, 2017 | 03:54 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
I run Cooper whitewalls on my 57. Very good tires that wear well and give a great ride for the price.
Old Jul 10, 2017 | 04:11 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Another vote for the Hankook H724 radials P205R75-15
I've got 5K miles on them and they still look new.
No issues whatsoever.
Old Jul 10, 2017 | 04:37 PM
old68's Avatar
old68
Default are the 215 70 15's slightly wider & taller than 205 75 15?
Gary
Old Jul 10, 2017 | 04:59 PM
GCD1962's Avatar
GCD1962
Just put some on my '62. Tires-easy had them for less than $70 each. Great deal
Old Jul 10, 2017 | 05:11 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Tiger Paw AWP-IIs in whitewall are universally available, inexpensive and wear well...
Old Jul 10, 2017 | 05:44 PM
leif.anderson93
According to Diamondback Tires catalog:
205/75R15 27.1" height 5.3" tread width
215/70R/15 26.9" height 6.0" tread width
Go with the 215/70, they look better and perform better
Old Jul 10, 2017 | 09:42 PM
Gary's '66's Avatar
Gary's '66
Hope this answers your question and, just to add, the Diamondbacks are actually slightly narrower than the Toyo's on my American racing wheels. They should fit just fine.
Gary
Old Jul 10, 2017 | 09:54 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Yes, these.
Old Jul 10, 2017 | 10:16 PM
Ol Blue's Avatar
Ol Blue
2024 C3 of the Year Finalist- Unmodified
I went with Michelin Defenders on my KO wheels, 205/70's in front for better clearance and 215/70 on the rear. At full-turn with a half inch left before hitting rubber bumper in front A-frame I have 1/8" clearance between tire and fender, and I trimmed my inner fender lips back years ago when I put Polyglas GT's on it. I may put a spacer under rubber bumper so even if I bottom out in a field or steep angle driveway entrance the tire won't hit the fender.
The 215/70 just fit in the spare tire tub by using bolts for the 775 gold lines on 65's.
I have original springs so my car may sit lower than some with new springs.
To tire help
