[C1] Door alignment
Old Jul 15, 2017 | 11:51 AM
tonymcilroy's Avatar
tonymcilroy
Default Door alignment
I need to replace the bushing and pin in the door hinge. I had a real hard time getting the door aligned the last time. What is the "secret" to getting this aligned. I'm working on a 61.
Old Jul 15, 2017 | 02:40 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
The ST-12 describes C1 door alignment:
http://chevy.oldcarmanualproject.com...62csg0113.html
Old Jul 15, 2017 | 04:55 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Are the doors still on the car and properly aligned?
When I was building my '59 I had lots of fiberglass repairs on the passenger side door. After making the repairs I test fitted the door and had it properly aligned including the latch mechanism. I knew I would be removing the doors for painting, so I devised a method of returning the hinges to the correctly aligned position. On each door hinge I drilled two 1/8" holes which extended all the way through the nut plate. I took some 1/8" stainless welding rod, pointed one end of each rod, and stuck them through from the outside of the hinge. Now I could remove the rods and hinges, paint the doors (with the hinges attached) and align them with the rods.
Charles
Old Jul 15, 2017 | 07:21 PM
rtruman's Avatar
rtruman
Charles
I like that
To Door alignment
