1962 Rims and Tires??
Old 07-19-2017, 12:25 PM
buzzy62
Navigator
buzzy62's Avatar
Default 1962 Rims and Tires??
My buddy Troy told me I had to join this awesome forum, so here I am.
I’m hoping someone can help me, I’ve just got my first vette, 1962 and I’m going to put some Torque Thrusts on there and I’m wondering what’s the widest tire I can fit under it, without actual trial and error and was hoping one of you would know and let me know.
Thanks in advance!
Tim
Old 07-19-2017, 12:35 PM
C-1 Generation 2
C-1 Generation 2's Avatar
Here's a link that might help:
http://stl-vettes.com/65Vette/wheels.../C1_Wheels.htm
buzzy62 (07-20-2017)
Old 07-19-2017, 01:17 PM
Plasticman
Plasticman's Avatar
I have AR TTD 15x6" wide wheels on my 62, and 235's are as wide as you want to go on the rear. I run 215's on the front, since turning is easier than with wider tires (with the original manual steering).
245's were possible (according to my measurements) on the rear, but that did not take in body mount differences that occurred in production, rear leaf spring & rubber bushing deflection, etc. I have had the 235's on the rear since 2000 with no issues.
Plasticman
Old 07-19-2017, 03:50 PM
toddalin
toddalin's Avatar
Received 1,170 Likes on 487 Posts
I was looking at Tire Rack ad that came out today and they have 15x6 TT on sale.
Old 07-19-2017, 04:38 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
can't find them...
Bill
Old 07-19-2017, 04:53 PM
buzzy62
Navigator
buzzy62's Avatar
Originally Posted by C-1 Generation 2
Thank You!
Old 07-19-2017, 04:54 PM
buzzy62
Navigator
buzzy62's Avatar
Plasticman
Thank You, perfect!
Old 07-19-2017, 05:08 PM
toddalin
toddalin's Avatar
Originally Posted by wmf62
can't find them...
Bill
https://www.tirerack.com/specialoffe...p+to+50%25+Off.
https://www.tirerack.com/wheels/resu...erSpecial=true
Old 07-19-2017, 05:12 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
thank you
Bill
Old 07-19-2017, 08:02 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Welcome to the best forum for C1s......62s are the best!
Let's see some pics of your car.
here's mine....7x15 in. 68 Vette wheels with 215s and 66 vette hubcaps
Old 07-19-2017, 10:51 PM
68hemi
68hemi's Avatar
Received 3,048 Likes on 1,934 Posts
C1 of Year Finalist (performance mods) 2019
Thanks in advance!
Tim
Depends on many things as others have stated but also on of the most important things that will effect this is the back spacing of the wheels.
Old 07-19-2017, 11:22 PM
Plasticman
Plasticman's Avatar
The "standard" backspacing on the AR TTD 15"x6" wheels has been 3.66", as listed here:
http://www.americanracing.com/wheelS...-torq-thrust-d
Oddly enough, the specs listed on Tire Rack are 3.54" (for what appear to be the same rims - VN105xxxx).......as listed here:
https://www.tirerack.com/wheels/Whee...4&autoModClar=
Plasticman
Old 07-20-2017, 12:02 AM
68hemi
68hemi's Avatar
Plasticman
I am assuming you are speaking of the original wheels. OP did not state if the wheels he plans to use are originals or repos. I believe the repos are available in many sizes and back spacing.
Old 07-20-2017, 09:40 AM
buzzy62
Navigator
buzzy62's Avatar
here's a couple of pic's of my car, i've got to get some better ones.
Kerrmudgeon (07-20-2017)
Old 07-20-2017, 10:01 AM
Plasticman
Plasticman's Avatar
I was speaking of what are currently listed on the linked websites (AR and Tire Rack) , which I hope are selling current product, but also my 2000 new purchased 15x6 TTDs have the 3.66" back spacing.
Also, my 1966 Vette with 1970 new purchased AR TTD rims had the same backspacing, so I do think there is a commonality across the AR line (again, only speaking of the 15x6 rims).
The fact that Tire Rack has a different backspacing (for the same rim) makes me a tad suspicious.......and I would question them, prior to any purchase.
Since the OP asked specially about Torque Thrust rims, I assumed he was talking about American Racing Torq Thrust rims. Other aftermarket rims, that look like AR TTD rims, obviously could be all over the map (backspacing wise, as well as other dimensions, and quality).
Plasticman
Old 07-20-2017, 12:17 PM
buzzy62
Navigator
buzzy62's Avatar
Plasticman
Yes, I'm talking about the American Racing Torq Thrust rim.
Old 07-20-2017, 12:24 PM
buzzy62
Navigator
buzzy62's Avatar
Plasticman
you have the 235's on the rear, are you using the standard back spaced rim that AR suggests on there site?
To 1962 Rims and Tires??
Old 07-20-2017, 12:27 PM
Plasticman
Plasticman's Avatar
Plasticman
Mine are the standard 3.66" backspacing in 15X6 (with 215 front tires and 235 rear tires).
Plasticman
Old 07-20-2017, 02:09 PM
toddalin
toddalin's Avatar
Plasticman
You are looking at less than 1/8" difference. This may or may not even affect clearance.
But is it also possible that they are not measuring the same thing?
My Western Wheels have a raised lip along the inside edge. I've seen where people either consider or don't consider this lip in their measurements.
Old 07-20-2017, 02:18 PM
XCSP700
XCSP700's Avatar
I have Americans on the front of mine, 15x6 with a 205/75r15. It looks good and steers easy. In the back I have 15x8 steel wheels so I'm not sure what will fit good there. They are 225s with plenty of room
buzzy62 (07-21-2017)
Quick Reply: 1962 Rims and Tires??
