c2 LED Headlight recommendation
I've read a few threads about this but they all get closed with no info. regarding recommended vendors. Can anyone please PM me what brand you've used and if you're happy with them?
Thanks in advance.
Ken
Thanks in advance.
Ken
I looked recently and could not find any led head lights that are a direct bolt in for a c2.
Dave
Dave
Received 2,127 Likes
Look at Marchal, Hella and Cibie. I put Hella low beam 55watt 35-40 years ago. Never had one burn out yet, much better lighting. Dennis
The Halogens won't tax your stock electrical wiring and are bright enough for me with the little bit of night driving I do... I also wasn't aware of any direct fit LED options..
This appears to what you have to do to install LED headlights, the article is for replaceable bulb halogens, but the LEDS are also long in back due to the heat sink/heat radiator and would need the same modifications. I am not familiar with how much room is in the C2 headlight buckets, YMMV..
Sealer beam Halogens should drop right in.
http://www.hotrod.com/articles/conve...en-headlights/
Sylvania H5001 and H5006 Halogens (if I remember the numbers correctly) are plug-and-play -- no mods required.
JC_ (04-08-2019)
Thanks for the replies. I'm (my customer) is interested in LED headlights. They will not be drop in replacements as noted above and could (should) be even brighter than Halogens and draw less power (not that it matters much). Has anyone actually installed LEDs and what do you think of the performance?
Received 1,120 Likes
2017 C2 of Year Finalist
The 63 installation requires substantial modification of the fins on the back of the bulb (the pic below shows an early iteration of the fin mods, as well as modification of the adjustment can that it sits). Note that 63 cars are different in that they have an additional bracket inside the lamp enclosure that is not found in later c2s. That 63-only bracket caused the interference that required the fin modification. I'm not sure that much, if any, fin modification would be necessary on later C2s.
I hope that helps,
Mike
Ken Sungela (07-28-2017)
The following 5 users liked this post by out2kayak:
63Corvette (08-14-2017),
C2Racer (12-19-2020),
Ken Sungela (07-28-2017),
number3 (07-24-2017),
Sky65 (07-23-2017)
I have Oracle led headlights #6913-001 in my 63 conv. the difference is incredible they are not plug & play, they require the same modifications as Tom's in post #8. I have a set set sitting on my bench to install in my 63 coupe. The yellow high beams in the last picture are halogen H5006's notice how yellow they look I'm going to just unplug them they really don't do anything.
Mark
Mark
Thanks for the feedback guys. Looks like the warranty is voided after cutting the cooling fins off. I guess either cut the fins or the cup.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
DON'T DO IT!!!
Some of these new lights are blinding to oncoming traffic. You don't want someone running into you because YOUR lights are too bright for them to see.
I've just received one of these bulbs, that I think can be installed without any fin modification:
I'll still have modify the can below, but that's not that difficult.
Stay tuned...
Mike
Stay tuned...
Mike
St. Jude Donor '05, '09, '15
Tom
That said, I still like 'em. I have a '67 Chevelle that I'm putting together and am going to figure out how it will work on there (an LT4 is going in there and DeWitt's is pulling together the cooling "stack", along with other space consumers).
The thing with the Chevelle is that I want to do something like the 2015 Challenger Hellcat headlight setup and this style of light will work well with that.
FWIW...
-- Joe
Sky65 (08-13-2017)
I was just about to purchase the Daymaker lights but then read some reviews from the Harley guys about LED headlights in general not illuminating the side areas of the road. Thus creating the issue of not seeing the road when turning. What has anyone'e experience been with this issue and LED headlights? Also, are you guys using the same headlight for both the low beam and high beam?
