Car running warm 64 Coupe
A friend has a 64 coupe 365 horse, it is running a little warm New DeWitts, hoses,clutch fan, everything new ecept water pump looking for suggestions on what might be wrong gauge is new also HELP
First and foremost and always in these issues is to confirm its REALLY running warm...the temp sending units are notorious for reading high. An I/R temp gun aimed at the thermostat housing on the hot car will do the job to validate the gauge reading.
Where is the initial timing set and is the vacuum advance working properly.
Received 1,857 Likes
Read this and learn how your Corvette cooling system works and how to properly diagnose and repair it:
Test
The thermostat housing is what I use to check the temp. I also do the top and bottom hoses for a differential reference. Hot going in cool going out. My temp sender is off by about ten degrees.
black35 (07-26-2017)
And, hold the IR gun no further than 6" from the area you are wanting to read...much more accurate
