[C2] 694 vs. 750 alternator
I found a section within a GM Heritage Center PDF that lists the 327 w/ air conditioning could use the 694 or the 750 alternator. Is this true? If so, I would much rather go with the 61A 750 alternator vs the 55A. Would it matter for California cars that had A.I.R.? I just want to make sure I get the correct one since they can be pretty expensive rebuilt. The one I have in there currently is a 61A from a 72 Corvette/Camaro.
Received 6,943 Likes
2015 C2 of Year Finalist
AIR would have no effect on the alternator. Only AC and TI effected the alt used. With only one of the two the 51 amp rating A car with both AC and TI would get the 61 amp
Not certain about 1966 or earlier/later 1967's.
Larry
66blackvert (07-23-2017)
Mine only has AC...no TI. It is an early VIN (OCT 65).
I know that's how GM wanted it to happen but what really happend is a diffreant story
Anybody out there know about the 66 model year and how they distributed the alternators? If I get a 55A 694, will I have any issues? Anyone out there use the 694 with AC?
NCRS Judging Manual for 1966 model year shows #750 alternator as the primary alternator for 327 engines with either AC or the combination of TI and AC. They footnote that alternator could be #694 if only had AC and not TI.
327/300 engines could not get TI..........only 327/350 engines could get TI as an option. Obviously TI was also available for the BB engines.
The 1966 Judging Manual shows #696 42 amp alternator for engines with TI only.
Larry
Larry
Awesome. Thanks Larry! So it looks like I could go with either by NCRS and still be good. I think I will look for a 750, because why not get the larger one if you have the option?
Larry.
