[C2] Paint Bubbles Problem
Old Jul 28, 2017 | 10:41 AM
KenRice's Avatar
KenRice
3rd Gear
Default Paint Bubbles Problem
I've been reading up on dealing with bubbles in the paint section. I've recently looked at 1963 that was not repainted but had bubbles roughly the size of a nickel over the majority of the car. Being that the problem covers the majority of the car, would you still consider purchasing it? Thank you in advance.
Old Jul 28, 2017 | 10:49 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
If its original lacquer the paint usually cracks and spiderwebs.
If the bubbles are tiny on a recent paint job it could be solvent "pop".
If its an older re-paint with larger bubbles its bad adhesion and/or body work.
Its like being a "little bit pregnant"...
You either live with it or count on a strip and repaint IMO.
Old Jul 28, 2017 | 11:47 AM
KenRice's Avatar
KenRice
3rd Gear
Thank you. After stripping and repainting, is this problem likely to reoccur?
Old Jul 28, 2017 | 12:49 PM
DansYellow66's Avatar
DansYellow66
Frankie summed it up perfectly - I would be nearly 99% sure it has been repainted at least once in the past. I've not heard of original GM lacquer developing the bigger bubble/blisters.
Old Jul 28, 2017 | 01:11 PM
Brucebodyman's Avatar
Brucebodyman
I agree with Frankie. Car must be stripped and painted. Figure $20K. If car can be bought reasonably and your willing to go through the process it wouldn't deter me.
Old Jul 28, 2017 | 01:35 PM
domenic tallarita's Avatar
domenic tallarita
I agree with all above,and I had that happen to me in the 70's.
I used one of the first 2 part primers to lock down the bare glass, then used laquer primer over that as a light fill. About 6 month later the blisters started to appear.
Paint shop told me that it was bad catalyst. But as stated above it could have been the reducer. There was a hint of powder under each blister which made me also think that I used to much reducer and burned the paint.
That was a poly 2 part primer, but the 2 part epoxy primers are great.
Dom
To Paint Bubbles Problem
