Build date
Old Aug 4, 2017 | 10:02 AM
Govoni Farm's Avatar
Govoni Farm
Default Build date
Good morning. I have a 1967 vette that was built 1/18/67. Would that be considered an early built date? Also does DOT 5 brake fluid eat the seals in the calipers and do you recommend using it? Thanks for your time on this. John
Old Aug 4, 2017 | 11:11 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
A Jan. built 67 would be right in the middle of early late builds. They started building in Aug. & stopped in late July. No the DOT 5 will not eat the seals.
Old Aug 4, 2017 | 11:34 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
early and late depends on the part your talking about. Not the cars build date
Old Aug 4, 2017 | 11:38 AM
kenba's Avatar
kenba
You are right. He didn't say he was asking about parts but I assume you are right that is why he was asking.
Old Aug 4, 2017 | 11:59 AM
Powershift's Avatar
Powershift
This is how many folks interpret the early/late question, and it is probably the correct way.
Having said that, I would also say (in general) that an August-September car is "early" and a July-August car is "late". This is where parts from a previous year (early) could be installed or parts from the new model year (late) could be installed due to current model year parts not being available. FWIW.
If you use DOT 5 fluid, buy it from a major, "name-brand" source. Not from anybody. I believe Wilwood sells it, also Muskegon Brake, and Stainless Steel Brakes. I buy from the latter source, and the last time I went thru Corvette Central who stocked it. Be aware, some brake companies will not honor warranty claims if DOT 5 is used. However, a number of us have successfully used it for over 20-25 years.
Larry
Old Aug 4, 2017 | 02:40 PM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Larry
We have stopped selling and so have many other vendors due to the change in formulation brought on by the EPA approximately 1.5 years ago. They forced the manufacturers of the Silicone fluid to change their formula and the result is that the fluid is causing seals to swell and leak. There have been a lot of people using it and unfortunately with the government there isn't a fast fix. That's why the warranty is being voided if silicone is used. It isn't where you get it, it's a government standard now. Hopefully they can get it situated so we can all enjoy the benefits of DOT5 again soon.
Old Aug 4, 2017 | 04:29 PM
20round's Avatar
20round
C2 of Year Finalist (stock) 2019
I bought my complete brake set up from you in 2014. and it came with 2 qrts of dot5 ? should I use it or not? I have not put any fluid in the system at all yet. thanks troy
Old Aug 5, 2017 | 08:01 AM
Govoni Farm
Yes I was wondering about parts. So I assume parts like brake calipers could be early or late production numbers. Thanks
Old Aug 5, 2017 | 08:09 AM
Govoni Farm
Larry
Larry, I had several calipers all of a sudden start leaking. It has J 56 brakes on the front so those will have to be rebuilt. I think I will change the fluid to DOT 3. What brand do you guys recommend. John
Old Aug 5, 2017 | 08:14 AM
Govoni Farm
Thanks everyone for all your feed back. This Forum is just soo great. John
Old Aug 5, 2017 | 10:41 AM
Powershift's Avatar
Powershift
Any major brand of DOT 3 should be fine. Prestone, Castrol, etc. The BEST one used by the racers is available from Ford. Richard Newton (RIP) mentioned it in his article on this forum regarding brakes a few years back. I used it long before that, and got the part number from the NASCAR racers. A Goggle search should also find the part number.
What brand DOT 5 were you using??
Since my current supply of DOT 5 is from SSBC from 20 years ago, I am probably safe for now, but one day I will need to restock. Oh well........
Larry
EDIT: I believe this is the stuff:
Amazon Amazon
Old Aug 5, 2017 | 11:20 AM
Govoni Farm
Larry
EDIT: I believe this is the stuff: https://www.amazon.com/Genuine-Ford-.../dp/B000NU39IC
I got the DOT 5 from NAPA.
To Build date
