When rebuilding my 64 (small block), I opted for these front coils recommended by Zip for easy install. http://www.zip-corvette.com/63-67-c2...l-springs.html
Little did I know (then, 4 years ago..) that they were probably much stiffer than the originals (less coils, thicker wire). According to Zip these are close to factory F41 specs, at least double stiffness compared to standard.
Now that I drive the car, I find them too harsh and want to replace them with the originals. I have seen those from LICorvette http://www.parts123.com/parts123/yb....ort~1~cadeikba , those at ZIP http://www.zip-corvette.com/63-67-c2...s-correct.html and mamotorworks http://www.mamotorworks.com/Corvette...oated-623208-1. To me they all look very similar (which does not mean too much I know) , although the price of LiC is much higher (185$ versus 120$) . Are the LIC's worth the extra?
Corvette parts suppliers call these the "Grand Touring" springs. Rated heavier than the stock spring (293 lb./in.) and lighter than the F-41 springs (550 lb./in).
what I read (JohnZ, LIC, Eaton, etc) is that the stock springs for a 64 with 327 are about 200 lb/in. See below a copy of a post on another forum. The ones I have on now show a bar diameter of about 18.5mm , and 6 coils I believe. So what I have may already be close to the springs you refer to, and that's the ones I don't like
I used 350 lb/in springs with my front coil overs. F41 springs at 550 lb/in. are too stiff for everyday driving. My LS engine is lighter. You probably need a 400 lb/in. spring.
Why would I need a 400lb/in spring if the originals were just half of that? My car is a cruiser.
You don't. But I would suggest something marginally heavier than the stock GM coil. I purchased a stock set over the counter from Chevrolet with original part numbers back in the early 90s. It was difficult at the time finding proper std suspension BB springs. Since my car had an aluminum head & intake BB and no power accessories, I thought the stock SB spring might work OK.
It did sit well and ride smoothly for about a year but the front of the car just kept settling lower and lower until one day I lightly bottomed out one of my side pipes at the front. When I got underneath and looked at the coils, they were now so closed up (collapsed) there was hardly any space between them. I don't think my car is really any heavier than a 300 HP small block with PS & PB. I wouldn't put those springs on any Corvette.
If you want a custom spring wound to stock or custom specs you might try Coil Springs Specialty in St. Mary's Kansas. That's were I had my replacements made which I very slightly heavier than the standard BB spring. I don't know if they ship out of the country.
I understand the sagging problem. But isn't that more related to the quality of the spring steel used? Heavy duty springs will (over time) sag less under comparable load than softer ones, for sure. Both both should not sag substantially when loaded within their specs and expected lifetime. Or do I see it wrong?
I'll check with Eaton and Coil Springs Specialty (thanks for the tip!) about the sagging, eventually the 2017 steel quality they select is better than 20 years or 50 years ago
With diameter, wire thickness and number of active coils I calculated that the coils I have on are around 500lbs/inch. That is way above the 200 standard, and leaves enough space in between to go softer.
I think you see it correctly. Some slight settlement after firs installation is expected but should rapidly diminish within the first few weeks and continue to decrease until the spring is for all practical purposes, stabilized and remain fairly constant for a reasonable period of time depending on how the car is driven, etc. Those GM coils just kept getting more and more compressed with time. I was taking measurements on the suspension for awhile and it just kept settling which after a year or so and the light bottoming I experienced, told me I was going to have to find something else.
My point is I would buy a spring from a quality aftermarket firm like Moog, Eaton or Coil Springs Specialty. I suspect some of those old GM replacement springs are still around and I wouldn't waste money on them.
