[C2] '63 SWC Engine Issues
Old Aug 13, 2017 | 04:15 PM
misa84's Avatar
misa84
Default '63 SWC Engine Issues
Well, I am stumped. In my 63 the engine is a later year block with the casting number of 3970010. From what I can find that could be a 327 or 350. I have two questions, how do I determine which cu. in. displacement it is. Secondly, and more important the engine vibrates (really vibrates) when I speed in up (in neautral - 4 speed) I have checked the harmonic balancer and it seems ok. One thing I noticed is that the water pump pulley, aletrnator pulley and damper pulley are not parallel. The water pump pulley seems to be further out towards the front of the car which causes the belt to be crooked???
I do intend to swap motors when I can find a 327/340hp year appropriate engine. Unfortunately, my friend who GAVE me the car passed away and I have no idea from whom he purhcased it.
Any help is grealy appreciated.
Thanks,
Peter
Old Aug 13, 2017 | 04:32 PM
hedgehead's Avatar
hedgehead
From: I'm not doing as well as I expected, but I never expected I would
So many things. You might start with the pulley problem, check your clutch/pressure plate. Post your engines casting date. And the pad info. Pics when you get them.
Old Aug 13, 2017 | 04:50 PM
Boyan's Avatar
Boyan
Default Engine
Dont worry about what cu in it is. The only way to deterime that is with a full teardown and see what kind of parts are in it now. It could even be a 383, you just dont know. Fix the vibration and enjoy your friends memory with the car. In addition to the belt being off set, look for pulleys out of round.
Old Aug 13, 2017 | 04:57 PM
JohnZ's Avatar
JohnZ
Peter
About seven million 3970010 blocks were cast from late 1969 through 1979 - it was introduced along with the new "long" water pump accessory drive system in 1969 that moved the alternator to the passenger side (only on passenger cars and trucks, not on Corvettes). Externally, you can't tell whether it has a 3.00" crank (302), 3.25" crank (327), or 3.48" crank (350) unless you can see the shape of the flywheel flange on the crank or if the front pad stampings are readable. Otherwise, you have to tear it down and see what pistons and crank are in it (rods are all 5.7").
You may have a mis-match of pulleys and a "long" water pump, which will require replacement.
Old Aug 13, 2017 | 05:19 PM
misa84's Avatar
misa84
Thanks. I think you are right about th water pump. What pump should I replace this one with?
Old Aug 13, 2017 | 06:27 PM
MikeM's Avatar
MikeM
Don't you think you're jumping the gun a little?
First thing to do is take the fan belt off and run the engine and see if the vibration goes away. Then, report back what you find and what pump is on your engine.
Old Aug 13, 2017 | 07:03 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Yes, you need to address the mis-aligned pulleys but they are not going to cause a vibration.
There are many things that can cause vibration such as a misfiring engine. Since you don't seem to know much about the cars engine, my first real concern is weather the engine is internally balanced or externally balanced. The balancer would need to be a neutral type if it is externally balanced with the correct balanced flywheel. You don't want to run and rev the engine much if this engine is not balance properly as it could cause some serious damage.
Old Aug 14, 2017 | 04:59 PM
Shift_Happens's Avatar
Shift_Happens
Thanks,
Peter
So, just to be clear, the car is not moving and the engine vibrates in neutral at high RPM?
Old Aug 14, 2017 | 05:28 PM
colo63sw's Avatar
colo63sw
Are you sure all 8 cylinders are firing? All 8 plug wires are good and all 8 spark plugs are good? Timing sequence correct on the plug wires.
Need to start at basics with inherited stuff.
Old Aug 22, 2017 | 04:39 PM
misa84's Avatar
misa84
Default 63 Long Water Pumo
Sorry I took so long in responding to all, but just had 4 plates put in my neck (fusion) so I have been a little lazy. Anyway, the casting number on the water pump is 372608. When I took off the belt ane ran the engine the vibration was gone. Can you tall me the correct part number for the shorter pump. Trying to attach some pictures.
Thanks much for your help,
Regards,
Peter
Old Aug 22, 2017 | 05:31 PM
MikeM's Avatar
MikeM
The 608 should work fine on your engine.
Read this thread for a possible issue on your engine concerning pump shaft size and fan clutch hub size.
https://www.corvetteforum.com/forums...lutch-fan.html
If you don't find anything here, you can remove the fan blade, install the fan bellt and see if the vibration is still gone. You may have an out of balance fan blade.
I can't see your pictures so this is all I can tell you.
Old Aug 22, 2017 | 06:15 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
010 blocks are all internal balance.
Old Aug 22, 2017 | 07:28 PM
pop23235's Avatar
pop23235
Looks like the 350 cu in balancer too.
Old Aug 22, 2017 | 08:57 PM
misa84's Avatar
misa84
What about the water pump pulley not being aligned wih the alternator and crank pullys? Are there different pulleys available? The WP pulley is about 1/2 inch too far forward.
Thanks.
Old Aug 23, 2017 | 09:07 AM
MikeM's Avatar
MikeM
I can't see your pictures.
Old Aug 25, 2017 | 09:23 PM
JohnZ's Avatar
JohnZ
Thanks.
There are HUNDREDS of combinations of different diameter/depth/width/offset pulleys; you need to get the correct ones for your particular application, and they'll work fine.
Old Aug 25, 2017 | 10:04 PM
Robert61's Avatar
Robert61
Yours is the short water pump
To '63 SWC Engine Issues
Old Aug 26, 2017 | 07:17 AM
DansYellow66's Avatar
DansYellow66
I don't know how much misalignment of pulleys you have, but when installing the new water pump you can test fit it and the pulley and if it doesn't align perfectly - the hub on the water pump is a press fit and can be moved in with a press or vice and pulled out with a gear puller to slightly adjust.
Old Aug 26, 2017 | 09:29 AM
Robert61's Avatar
Robert61
They also make shims you can use either on the water pump or the crank pulley for alignment.
Old Aug 26, 2017 | 10:01 AM
426 Hemi's Avatar
426 Hemi
Might be worth throwing an eyeball on the lower pulley to see if it's cracked----usually around the bolt holes.
