Removing shift boot
Old Aug 16, 2017 | 12:35 AM
40ZR1's Avatar
40ZR1
Default Removing shift boot
'60 corvette 4 speed shift boot is torn. Have removed two phillip screws but can't lift or rotate shift console cover, feels like it's bolted from underneath. Is something holding it on? Any help appreciated.
CJ
Old Aug 16, 2017 | 07:22 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
You DO know you have to lift the shift indicator plate to get to the 'real' mounting screws ? Right ?
Old Aug 16, 2017 | 11:29 AM
65GGvert's Avatar
65GGvert
As Frankie said, the top two screws only hold on the shift pattern plate:
Then after you lift up the plate, there are two long screws that go into captive nuts on the bottom side of the hump, above the transmission:
On mine, one of the captive nuts had broken loose and I needed to have someone under the car holding the nut while I removed the screw from the top. I used JBWeld to "recapture" the nut.
Old Aug 16, 2017 | 07:04 PM
40ZR1's Avatar
40ZR1
FTF and 65GG, thanks for the quick reply. But Frank, I like your replies to threads because of your computer skills for including pics/diagrams but 65GG saved your bacon!
Thanks, again.
CJ
How do you use/find the thank button?
Oops, I found it
Old Aug 16, 2017 | 07:50 PM
65GGvert's Avatar
65GGvert
Thanks, but Frankie's bacon was fine. Your bacon wasn't cooking.
To Removing shift boot
