numbers help ??????
Old Oct 4, 2002 | 10:56 AM
59intheworks's Avatar
59intheworks
Default numbers help ??????
Any info would be helpful.
Diff. 3707308(the 8 may be a 6) GM3
Master Cylinder 5456022
10168 1" Dia R4
end plate 5454480 320-G
Delco
Moraine Products Div.
Dayton O. USA
Thanks for any help, Ray
Old Oct 4, 2002 | 11:14 AM
67HEAVEN's Avatar
67HEAVEN
Default Re: numbers help ?????? (59intheworks)
10168 1" Dia R4
Delco Moraine Products Div.
Dayton O. USA
On the master cylinder, one source says 1957 to January 1959 while another includes up to 1962?
:confused:
Old Oct 4, 2002 | 04:03 PM
JohnZ's Avatar
JohnZ
Default Re: numbers help ?????? (67HEAVEN)
It's 3707306, which was a one-year-only 1956 Corvette center section casting, used with open-only diffs (no Positraction until 1957, which used a different casting).
The numbers on the master cylinder are good - it should also have a cast iron cap with 5300880 cast in it; if the car was built before January '59, the last three digits of the master cylinder casting number ("022") will be the same size as the first four digits; if it was built after mid-January, those last three digits will be larger than the first four.
Old Oct 4, 2002 | 04:40 PM
59intheworks
Default Re: numbers help ?????? (JohnZ)
Thanks guys
John, I have a 59 and would like positraction. Since this is a one year only 56 item, is it something that has any extra value to someone rebuilding a 56? or should I just keep it in mine.
Thanks, Ray
Old Oct 4, 2002 | 05:10 PM
JohnZ's Avatar
JohnZ
Yes, it should be worth something to someone who's restoring a '56 to "numbers-correct"; after 46 years, many 56's have had the center sections replaced with later Posi pumpkins, and an original '56 unit would be a "find" for some of those guys.
To numbers help ??????
