Speedo Gear
First, how many teeth were on the gear you removed?
Second, how many teeth were on the gear you installed?
Yes, it makes a difference, because there are TWO different size DRIVE gears INSIDE the tranny and there are TWO different size DRIVEN gears which go into the side of the tail housing.
It is imperative that the drive and driven gears are the correct sizes so that they mate correctly.
The larger DRIVE gear inside the tail housing will only mate with the smaller 17-22 teeth DRIVEN gears.
The smaller DRIVE gear inside the tail housing will only mate with the larger 22-25 teeth DRIVEN gears.
Also, ALLLLLLLLLLLLLLLL the plastic driven gears are color coded. What was the color of the gear you removed and the color of the gear you installed?
Little things like this make a difference.
Here are the two different sizes of drive and driven gears. Not much difference, BUUUUUUUUUUUUUUT, the difference is enough that they won't mesh properly if they are not correctly matched.
