Adjusting clutch
Old Aug 20, 2017 | 05:06 PM
black35's Avatar
black35
Default Adjusting clutch
Just got 64 coupe and the release point for the clutch is at the top How do you adjust the pedal to release closer to the floor
Old Aug 20, 2017 | 06:13 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Adjustment is at the end of the rod under the master cylinder. Also, I hope your throw out bearing is positioned correctly in the fork opening and you have the correct throw out bearing. Two exist, one short, one long if I'm correct. And last, the clutch may just be worn out. Dennis
Old Aug 20, 2017 | 09:09 PM
JohnZ's Avatar
JohnZ
Forget about where the release point for the clutch is - that's not the criteria for the clutch adjustment. You adjust the nuts holding the clevis on the forward end of the pedal pushrod so you have an inch to an inch and a quarter of pedal free play at the pedal. Using any other criteria can result in a fried throwout bearing. If you can't meet the pedal free play requirement with the adjustment on the pushrod, you have excessive wear in the linkage or in the clutch.
Old Aug 21, 2017 | 10:12 AM
DansYellow66's Avatar
DansYellow66
If you have minimal or no free play at the top that is probably good as you should be able to back the adjustment on the rod back towards the firewall to adjust proper free play. For whatever reasons a lot of these cars are all adjusted out at the far end of the rod, and can't adjust further to get enough clutch release to avoid gear shifting problems.
Old Aug 21, 2017 | 08:45 PM
black35's Avatar
black35
Thank you for the helpful info
Old Aug 21, 2017 | 09:01 PM
buns's Avatar
buns
From the Service Manual:
To Adjusting clutch
