Help identify this motor
Hi Away from resources, can you tell me what this motor is from.
Pad V08088HE
71000299
Also what is the box that has the speedo cable going in/out with a plug socket?
67 corvette
Jack
Pad V08088HE
71000299
67 corvette
Jack
HE suffix in 67 is 327/300HP with 4bbl and manual. The intake is correct. There should be a date code near the intake number. Can you get the block number?
Ed
Ed
There's one too many digits in each of those first two numbers you gave.
An extra 8 in the engine code and an extra 0 in the vin for it to be a 67 Corvette, but the intake casting number is correct for a 67.
I agree that the one item is some form of aftermarket cruise control. No '67 SB Corvette came with that type carburetor. All '67 SB had a Holley List 3810...so not sure.
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
That is the casting date and it is G66=July 6th 166 so likely for a 1967 model car.
Received 1,920 Likes
G86 = July 8, 1966.
Correct for a 1967 engine built in the first several months of 67 production, most likely too late for a 66 (if this intake was used for a 66, I don't know - too lazy to break out the Colvin book this late).
Check the engine block casting date - it's on the rear block surface behind the distributor, IIRC.
That date is consistent (matches) the early vin (299), and I bet it aligns with the engine assembly date which I think reads August, 8, 1966 (your last 8 is actually a 6).
I would say you are matching up.
Ok what's the story ?
And as I said earlier, an extra digit on the stamp pad.. Recheck both stamps.
Same type of mistake in Vin
Jack
