58 under dash wires help needed
These wires are hanging and I'm stuck where they get plugged into:
1. Thru firewall to interior, black / white wire marked VMA5861 with round open end, has to connect to a screw or bolt somewhere.
2. From harness with turn signal fittings, male fittings all plugged in, one female tan wire hanging, not sure where this plugs into.
3. Turn signal wires are thru the steering column, connected as noted in #2 above, one black wire with male end hanging thru hole in steering column. Where does this plug into?
4. Gauge cluster wires, all connected except one short gray female wire, not sure where this plugs into.
Probable obvious brain freeze
, but I have everything connected except for these above 4 wires.Thanks, Doug
