[C2] Engine Sputter?
Holley PART# 0-82651SA (650 street hp mechanical secondary)
Mallory Unilite 3748201
Msd Blaster 2 coil
Spark plugs I noticed that 2 of the plugs were gapped all the way down to the electrode if that makes sense.
Spark plug wires
Msd 6al have a newer msd that i could swap to test
Alternator (90 amps)
voltage regulator
Ballast resistor .8 oms
Mechanical fuel pump 8psi
fuel filter
To me it seems like i have replaced everything that could be causing a hiccup in the system. I went threw the whole fuel system and electrical as well i have check the timing plenty of times and even reset it a few time to tdc and problem still continues the voltage is good as well. Fuel seems good the carb is out of the box im assuming that it should run some what threw the rpms even if it were to struggle it could rise over mid 2000's.
VIDEO of problem
Any help would be appreciated as well as shops that anyone has had experience with in the south Florida/Miami area. This is at my limit of knowledge and experience. Getting close to giving it to a shop or throwing in a new lsx myself.
Here is one on a '67 Chevelle..(red arrow)..
In addition you MUST use a stock ballast resistor with the Unilite and IIRC that should be 1.8 ohms for your car (not 0.8 ohms). Others will correct me if I got that wrong.. If your engine is not original then I'm not sure what is needed.
If that Holley has an electric choke try running a bit with the power lead unplugged..and tapped off.
Finally, I'd pull those same two plugs again and see if the gap has closed up...let us know what you find. There are several reasons this can occur.
Dennis
If not, then most of the exhaust from the right bank is forced through the intake cross over and out the left exhaust.
Also, check to make sure your mufflers have not fallen apart on the inside and you have no blockage.
