Electronic Tach ?
Electronic Tach ?
Just installed my new electronic tach and would like to know if i can wire it directly to the fuse block that would be switched power
would be great if i could connect to one of the single prong connections on left hand side of this pic
Thx
Steve
Thx
Steve
I believe the terminals on the left side marked "BRAKE AL" and "BACK UP" are switched and fused by the fuse on the right marked "BACK UP" and "BRAKE AL" . Check it with a voltmeter.
Charles
Charles
Canuck62 (09-22-2017)
Thank You
I was up early with a test light to find out which are always hot or not
i used the back up because it was empty
works great,,,Thank You
Steve
Steve
