Motor ID
Old Oct 6, 2017 | 03:12 PM
jladuke's Avatar
jladuke
2nd Gear
Default Motor ID
I have an engine casting #3789935 which is supposedly a 61-64 283 cu in.
Assembly ID #F-103 ID. From what I understand the F stands for Flint where the corvette motor is made. It has a 2 4 barrel intake GM part#3739653.
Is this a true vette motor? Would be willing to sell.
Old Oct 6, 2017 | 04:03 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum!
I'd suggest putting this information request on the C1/C2 section of the Forum: https://www.corvetteforum.com/forums...-1953-1967-21/
Good luck.
Old Oct 6, 2017 | 04:10 PM
Vette_DD's Avatar
Vette_DD
Good luck.
And if you want to sell it here on the forum, you need to post it here:
https://www.corvetteforum.com/forums...d-c2-parts-59/
Be sure to include a forum-required asking price.
Old Oct 6, 2017 | 05:13 PM
jehuds10's Avatar
jehuds10
Welcome to the forum!
Old Oct 6, 2017 | 05:19 PM
rkj427's Avatar
rkj427
Pro Mechanic
Google would assist with your casting number, and you may find the rest in the C1 - C2 area.
Old Oct 6, 2017 | 06:45 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome! Check in with the folks on the C1 C2 forum. There may be some help there.
Old Oct 6, 2017 | 10:19 PM
Moving this over to the C1 & C2 Corvettes Section. And as mentioned, if you intend to sell some parts, be sure to post them in the C1/C2 Parts for Sale section.
Old Oct 7, 2017 | 01:02 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
If you could post a pic of the engine stamp pad and the block casting date code (found on upper rear ledge, right side), it might answer a lot of questions.
Yes, the 3789935 block was a 283 but only used in Corvettes during 1961. The engine assembly stamp starting with “F” should be followed by a four number date code (month and day) and then a two-letter suffix. If you’re saying the suffix is “ID” it doesn’t track with any 283 suffix I can find. The “F” engine assembly stamp means it was made at Flint but not necessarily for a Corvette – they also made passenger and truck engines.
Old Oct 7, 2017 | 02:30 PM
emccomas's Avatar
emccomas
This is most likely F I03I D
Flint
I0 = October
3I - 31st
D = suffix code, 283, 2bbl, powerglide, in a passenger car 61-60=170hp, 63-64 = 195 hp
To Motor ID
