New "Vintage" Trick Flow heads
Supporting Vendor
We have racers that break stuff all the time. It's pretty common for them just to buy one head, so we're in the habit.
Here's some other things you'll need to buy:
FelPro intake gasket 1256 $17.97
FelPro exh Gaskets 1404 $15.97
Guideplates TFS-30400623-8 included
Studs TFS-51400613 included
Head Bolts TFS-92000 $79.97
MLS Head Gaskets TFS-30494060-040 $79.97
Autolite 3924 plugs $26.32
TFS pushrods $99.97
Parts total $319.20
Rockers vary based on flat tappet or roller etc., but the TFS-31400510 (1.5 ratio) or TFS-31400511 (1.6) run $289.97
TFS pushrods $99.97
Parts total $319.20
The following 2 users liked this post by TrickFlowTech:
biggd (10-20-2017),
Loren Smith (10-21-2017)
Supporting Vendor
The following 5 users liked this post by TrickFlowTech:
Drothgeb (11-22-2017),
Easy Rhino (10-20-2017),
Loren Smith (10-21-2017),
MarkC (10-20-2017),
Plasticman (10-20-2017)
1.94" for the exhaust valves seems unlikely. 1.6" or so, I'd venture.
Pop Chevy (07-02-2023)
Received 1,919 Likes
Received 3,043 Likes
St. Jude Donor '05
sr youre right my oversight!
What a stellar new product that should fly off the shelves. Double-humps and all! I would have gotten these for sure when my engine was redone a few years ago, had they been available.
Supporting Vendor
It's not too late If you don't have aluminum heads already, that 40lbs off the nose will make your car a little more spritely. Gorgeous car btw.
TrickFlowTech (10-20-2017)
#35
Just for grins have any tests been done on say a bone stock L79 with cast 461 or 462 heads upgraded to your new trick flow design? I am curious what would happen to the Horsepower and Torque map.
#38
One note - being aluminum, IIRC, the thumb rule is that aluminum heads allow another .5 compression ratio over iron heads due to greater thermal conductivity.
#40
