Corvette 283 vin help
I have a 283 corvette engine,Possibly? Heads are 3755550 castings dated 1958 with no tapped holes in the end,water pump,intake,carburetor all check out as 327 corvette but block vin is passenger car.I picked this engine up at an auction.people claim that it was in barn for 40 years.any thoughts or info?
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,358 Likes
Moving from Parts Classifieds to General Discussion.
Received 1,549 Likes
What are the block casting numbers, date, and numbers on the front pad?
Received 6,997 Likes
2015 C2 of Year Finalist
It seems all SBC that were removed came from a Corvette. But truthfully he same block, heads and other parts were used on passinger cars and truck. There was no vin stamped on the block in Corvettes until mid 1960 production. And not on ALL engines until 1968 model year. Only the suffix code broke down to what car or truck it was used in
Block is 3756519 with F90 date code front stamp is F06I0E,heads are 3755550
with date codes g78 and g218 no tapped holes and staggered valve cover bolts crank is 3735236,carb is 3460s,intake is 3783244,water pump is 3859326
