[C1] Fuel Tank Relocation
Old Nov 29, 2017 | 01:32 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Originally Posted by cbernhardt
In case you are interested: When I was considering moving the fuel tank to the trunk I calculated the capacity of a round fuel cell, 8" deep, that would fit in the spare tire well -16.9 gallons.
Charles
Charles
just curious... is that a bladder type fuel cell or one with some kind of filler in it? if a filler, how much do you lose in capacity because of the filler?
Bill
Old Nov 29, 2017 | 02:17 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Originally Posted by wmf62
Charles
just curious... is that a bladder type fuel cell or one with some kind of filler in it? if a filler, how much do you lose in capacity because of the filler?Bill
The fuel cell in my '59 originally had foam filler, but I had read that some of the foam used in these cells tended to deteriorate over time. I took the foam out and replaced it with pieces of PVC tubing with holes drilled in them. The pieces of tubing are arranged vertically in the fuel cell. I gained almost 1 gallon by removing the foam.
Charles
Old Apr 11, 2021 | 04:43 PM
Fivepointfive's Avatar
Fivepointfive
Jim, Thinking Ralph Nader may disagree with you on this one. His book, "Unsafe at Any Speed" went after the Corvair in the '60's for having the gas tank immediately behind the occupants. The C-1 stock tank is 1/8 inch of fiberglass behind the driver and passenger, and Corvette bumpers are not famous for high levels of protection.
Old Apr 11, 2021 | 04:54 PM
Fivepointfive
whagge 70, The tail light filler is always a cool thing, Seen it on a few C-1, and i am about done with a prototype on my '54, but you are also correct that the tank needs to be below the filler. my tank will be in the tire well, so a little more plumbing, and I got it!
Old Apr 11, 2021 | 04:58 PM
Fivepointfive
Very nicely done. I would be thrilled to get that level of "Clean".
Old Apr 11, 2021 | 05:06 PM
vettebuyer6369's Avatar
vettebuyer6369
You are responding to multiple posts made 4 years ago.
