Side pipe cross pipe
Old Nov 10, 2017 | 07:09 PM
jaguardriver's Avatar
jaguardriver
Pro Mechanic
Default Side pipe cross pipe
I have read that a cross pipe will help smooth out and tone down the side pipes. Has anyone got a picture of an installed cross pipe? It is 1966 427. I had put one on a car years ago and it made the tone a bit more mellow, not much quieter, just smoother. Don't want to reinvent the wheel if someone can help with a picture.
Old Nov 10, 2017 | 10:47 PM
LT1driver's Avatar
LT1driver
bump for you
Old Nov 10, 2017 | 11:12 PM
Islander21's Avatar
Islander21
Originally Posted by LT1driver
bump for you
Couple of examples for you.
Old Nov 11, 2017 | 09:00 AM
jaguardriver
Pro Mechanic
Thanks, just what I needed. Now on to welding and fabricating.
Old Nov 12, 2017 | 10:24 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Here what I did ====> Click Here
George
Old Nov 12, 2017 | 12:27 PM
PAmotorman's Avatar
PAmotorman
it does not have to be as large a diameter as the exhaust pipes to be effective. just blocking the heat riser crossover in the intake manifold will change the tone of the exhaust. chevy put the cross over pipe on some FI corvettes to change the exhaust tone because the FI engine did not have a intake manifold heat riser cross over like carb engines.
Old Nov 12, 2017 | 01:42 PM
jaguardriver
Pro Mechanic
George
Thanks so much for the audio clips. That is the change I would like to hear. I had put a cross pipe on a Datsun 240Z years ago. Reason is it had a 400 CID Small block and there was not room enough for much in the way of muffling without going to really small pipes. The cross pipe did the trick. I did drive the Vette about 100 miles yesterday and the drone is kind of loud. This is with the Allen Quiet pipes.
Old Nov 12, 2017 | 01:54 PM
SAMMAN's Avatar
SAMMAN
2016 C2 of Year Finalist
I also have the Allen quiet pipes (66 427 L72), They were a little less noisy than the stock pipes, not much of an improvement. I changed my rear end from a 4:11 to a 3:08, now the pipes are no longer obnoxious and it’s a pleasure to drive the car.
To Side pipe cross pipe
