Refurbish Radiator or Replace?
Old Nov 30, 2017 | 12:18 AM
MrTwister's Avatar
MrTwister
Originally Posted by ricks327
If anyone decides to purchase a Dewitt's radiator, which I highly recommend, remember that a part of Dewitt's warranty requires the use of distilled water. No tap or well water.
Good to know - thanks!
Old Nov 30, 2017 | 11:18 AM
SWCDuke's Avatar
SWCDuke
Whenever the radiator is replaced, be sure to replace the two bottom rubber cushions and the rubber isolator at the top mount. These serve two purposes. First they provide some shock isolation. Second, and most important, they electrically isolate the radiator from vehicle ground.
If you have aluminum and iron immersed in an electrolyte and then electrically connect them you have a galvanic cell - otherwise know as a battery.
Electrical isolation from vehicle ground is important for all radiator materials, and aluminum is very sacrificial, more so than copper or brass when combined with iron, and will rapidly corrode. That's what causes those pinhole leaks and seepage.
With proper electrical isolation and a modern anti-freeze product (like Zerex G-05) mixed in a 50-70 percent proportion with distilled water and changed at least every five years regardless of mileage, a new DeWitts radiator should last at least several decades.
The reason to used distilled rather than tap water is to prevent the introduction of any unwanted ions that may deplete the corrosion inhibitors in the antifreeze and cause other problems. Domestic tap water often has a small amount of chlorine - not necessary enough to detect with you nose, but they are there and corrosive to cooling system components. Also, most tap water has calcium ions, which often combine with negative ions and precipitate out as solids that can clog radiator tubes and increase thermal resistance to heat transfer.
At about a buck a gallon it's foolish not to use distilled water.
It's amazing how long these radiators last despite often indifferent maintenance, and a few originals are still around, but likely living on borrowed time.
The Harrison Aluminum radiator in my SWC began to show evidence of seepage in the mid seventies despite biennial coolant changes. I always knew that the top was loose, and after buying an AIM about that time realized that the top mount rubber isolator was not installed at St. Louis. Having learned about galvanic cells and the electromotive force series in high school chemistry, I immediately understood why it failed so soon.
I bought a new replacement from GM, which were still available through service parts in that era.
Duke
Old Nov 30, 2017 | 11:26 AM
Mikado463's Avatar
Mikado463
good info Duke ......
Old Nov 30, 2017 | 11:28 AM
MrTwister's Avatar
MrTwister
Duke
Thank you, Duke! That is good to know... I will be sure to replace the rubber cushions and isolator when I replace my radiator. I'll be sure to use distilled water as well.
