64 Coupe Overheating
Old Dec 17, 2017 | 07:10 PM
black35's Avatar
black35
Default 64 Coupe Overheating
Put in a new radiator, water pump, hoses, etc. Have a problem with overheating. Thinking I might have an air pocket in the system. What is the best way to see if this is the problem and eliminate it.
Old Dec 17, 2017 | 07:18 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Is the cooling system, to the best of your knowledge, as original?
Also, what engine, and what options powered off of fan belts?
Old Dec 17, 2017 | 07:25 PM
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
Open the over flow tank (when cold) and the system will “burp” as the car warms up.
However, you might have other issues (timing, water pump, etc.) but I’d start with checking the coolant level and burping the system.
Do you have an IR thermometer to check the temp sensor, etc?
Good luck
Old Dec 18, 2017 | 04:23 PM
JohnZ's Avatar
JohnZ
Have you read this step-by-step article on diagnosing Corvette cooling systems? Hint: There's no such thing as a trapped "air pocket".
File Type: pdf
To 64 Coupe Overheating
