Caster
Old Dec 18, 2017 | 10:50 PM
MarkC's Avatar
MarkC
Veteran: Marine Corps
C2 of Year Finalist (performance mods) 2019
Default Caster
I now have Global West upper control arms and Del A Lum bushings. I am getting my car aligned Wednesday. GW recommends 3 degrees caster on the driver side and 3 1/2 degrees on the right with power steering. Other venders recommend up to 4.75 degrees. I don’t see a downside to increasing the caster as I welcome more resistance. I have Steeroids R & P. So do you guys have any opinions on this? I will not be tracking the car, just street driving. Thanks for your opinions.
Old Dec 18, 2017 | 11:07 PM
ChattanoogaJSB's Avatar
ChattanoogaJSB
mark- I'll wait on responses but I'm betting 5 is preferable
benton
Old Dec 18, 2017 | 11:17 PM
warrenmj's Avatar
warrenmj
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Wouldn't Global West know their product best?
Old Dec 18, 2017 | 11:45 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
I can't think of a good reason to set R caster different from L caster. If that were mine, I would make both sides the same.
3 degrees is a good value whether you have manual or power steering. If you want to go to 5 degrees, you really want to have PS (and since you have the Steeroids R&P, I assume you do.) because the steering effort will be measurably greater.
Jim
Old Dec 19, 2017 | 12:30 AM
tuxnharley's Avatar
tuxnharley
3*+ on both sides works great on my 67 with Borgeson PS.
Of course thats the most I could get with stock A arms and shafts.......
Old Dec 19, 2017 | 06:56 AM
MarkC's Avatar
MarkC
Here is what Jim at GW said, you will notice a huge difference from 1 to 3 degrees but very little from 3 to 5 degrees. Vette Brakes recommends 4.75 on both sides and I have seen others recommend 4 to 5. It surprised me that there opinions varied so much. My steering with the R & P is pretty easy to turn so that is the reason I wanted to go at least 4 degrees.
Old Dec 19, 2017 | 06:58 AM
MarkC's Avatar
MarkC
Jim
Thanks Jim, I like the increase in steering effort.
Old Dec 19, 2017 | 08:17 AM
jim lockwood
Originally Posted by MarkC
..... you will notice a huge difference from 1 to 3 degrees but very little from 3 to 5 degrees.
If this refers to a difference in steering effort, then I respectfully disagree.
On our two track cars, I initially set caster to 5 degrees. Both had manual steering at the time. After a few sessions, my bride complained about the steering effort. When I dialed back the caster on her car to 3 degrees she was a lot happier.
So, my experience is that the difference in effort between 3 and 5 degrees is significant.
Inside the control valve for your power steering will be (or should be) a replaceable spring which determines the overall amount of assistance your PS provides. To vary the steering effort to your liking, you ought to experiment with different springs.
Jim
Old Dec 19, 2017 | 08:31 AM
MarkC's Avatar
MarkC
Jim
He was not talking about the steering effort, he was referring high speed stability and the other advantages of increased caster. Like I said, increased effort is welcomed, my steering was too easy after the R & P install.
Old Dec 19, 2017 | 09:41 AM
SWCDuke's Avatar
SWCDuke
The benefits of high caster are better straight line tracking and self-aligning torque (which increases "steering feel") and increased negative camber gain on the inside wheel in a corner, which reduces understeer.
The downside is greater steering effort and kickback (especially in the case of manual steering). So it depends on the specific car and driver's preferences.
On my cars with power steering caster is set at the maximum positive value available within the adjustment range, equal on both sides. (Camber is at the maximum negative attainable value up to negative one degree, also equal on both sides.)
Camber and/or caster bias dates from the days of highly crowned dirt roads, say the 1920s. Modern paved roads, especially interstate highways have very little crown. So on a straight and level interstate highway with equal camber and caster on both sides, the car should very slowly drift to the right if you take your hands off the steering wheel, and this drift will be purely a function of road crown.
Prior to beginning to run my Cosworth Vega (manual steering) at track events in the early eighties, I set camber to negative one degree, but could only get zero caster. I wanted +1-2 degrees. Visual inspection revealed that I could get more caster by swapping the upper control arms side to side, so I did that and set it at the minimum caster setting available in that configuration, which was six degrees.
The test drive revealed that it turned in like a gokart, but had enough kick back to damn near break your arms, so it was back to the garage to swap the control arms back to their original location and live with zero caster.
Later I installed offset bushings on the upper control arms and was able to get +1 caster, which noticeably improved turn-in and steering feel without any objectionable kickback.
Duke
Old Dec 19, 2017 | 01:35 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Jim[/QUOTE]
I went through the futile search trying to find the heaver spring. The are unobtanium. I did manage to locate an old OEM valve and cannibalized the spring from it.
Old Dec 19, 2017 | 02:36 PM
John BX NY's Avatar
John BX NY
Not sure why they would spec out a lower caster on the LH side as that could make the car pull to the left.
In general more caster is a good thing but if you get to the limits for the suspension you could get into caster wobble.
Old Dec 19, 2017 | 03:25 PM
MikeM's Avatar
MikeM
See post #10.
Old Dec 19, 2017 | 03:34 PM
tuxnharley's Avatar
tuxnharley
Possibly an unnecssary attemt tp theoretically correct for road crown?
Old Dec 19, 2017 | 05:19 PM
MarkC's Avatar
MarkC
Thanks for your opinions and advice. I am going to go with 4.5 on both sides unless my alignment guy changes my mind. I am looking forward to the change.
Old Dec 19, 2017 | 06:29 PM
FLYNAVY30's Avatar
FLYNAVY30
Mark, who are you using locally for the alignment? I'm headed out next week for 6 months, but will be back next summer and high on the priority list is the disc brake swap, wheels and tires, followed by a performance alignment.
Hope all is well!
Old Dec 19, 2017 | 07:30 PM
MarkC's Avatar
MarkC
Hope all is well!
Bert’s alignment, they are across the street from the U Haul place on Virginia Beach Blvd between Witchduck and Independance. I understand they are the best around for older cars. Have fun on your deployment and be safe.
To Caster
Old Dec 20, 2017 | 09:17 AM
SWCDuke's Avatar
SWCDuke
Don't I know... My '88 MBZ 190E 2.6 has 10.5 degrees positive caster, power steering, and a deCarbon (high pressure gas) type steering damper.
deCarbon type dampers typically maintain their original damping characteristics until end of life when they completely fail.
One day the Merc front end goes into a violent shimmy at freeway speed the likes of which I have never experienced. So I removed one end of the damper and it was completely limp. Fortunately they are inexpensive (about 25 bucks) and easy to change.
I'm now on my second replacement. The first replacement failed as I departed Phoenix to return to LA about ten years ago. It was real tricky drive because I had to keep the speed less than about 60 or at least seventy and get up and down through the 60-70 speed range as fast as possible, which is where the shimmy occurred.
Duke
Old Dec 20, 2017 | 04:41 PM
MarkC's Avatar
MarkC
I got the alignment this morning and took the car out for a drive. The caster was set at 4.25 degrees positive. The steering resistance is up and the car tracks better at high speed. The steering is very crisp in the turns. This car just keeps getting better and better.
Old Dec 20, 2017 | 05:59 PM
Tom Austin's Avatar
Tom Austin
WHOA! Way to go Mark! Glad you like the new suspension/steering set up!
Tom
