[C2] Best way to clean aluminum expansion tank
As the title states, how is the best way to clean an aluminum expansion tank so that it does not have the shiny look, but rather the original aluminum look. The tank is in great shape, just has had some coolant overflow issues resulting in stains on the outside of the tank. Thanks All!! Al
The guys above are correct, red will ruin the finish. Depending on how bad the stains and oxidation are, I would go even light than green though. I use the white scotch brights (gray will even scratch a bit) and a little apple cider vinegar for aluminum. It removes most stains with destroying the natural patina and looking "over polished." Just remember, the more you work it, the shiner it is going to get, so work slow and rinse/clean wipe often.
Good luck
Mike
Good luck
Mike
Good luck
Mike
Good luck
Mike
Try aluminum jelly. I've used it for years and it works great. Looks just like the day the tank was made. Brush it on let sit for a few minutes rinse with warm water. May have to do it a few times depending how cruddy it is.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
what about straight vinegar? Would that remove stains but leave the surface alone?
The results were amazing,, scrubbing it a bit with a tooth brush... just a rinse after
Thanks guys for all the responses. Sounds like vinegar might be the liquid source I was going to ask about. I had thought of using water, but figured there was something that might preserve or restore the finish so it would not be shiny.
Other products that work the same can be found at truck stops and boat yards (pontoon cleaner).
Vinegar would probably work, although the "old school" solution was to use apple cider vinegar. I would be very careful if experimenting with naval jell as it can stain aluminum. Whatever you use, rinse regularly and thoroughly. If using abrasive pads and/or compounds, always start with the least abrasive and if need be, THEN go to the more abrasive solutions. Your object with aluminum is to retain the natural sheen/patina and avoid obvious scratch marks and over polishing. Have fun.
Mike
Mike
Hey Old Pervette, got the Scotch Bright pads today. Bought 2 gray ones and the store clerk gave me 4 white ones because he got tired of trying to find a part # or listing for them. The white one worked the best. The gray had a tendency to scratch. Experimented on the rear end of the tank that is not visible on the car. Tank now looks great again. Thanks everyone for the suggestions. Al
Received 5,610 Likes
Sounds like you found the solution. I used the red pads and WD40 to put a brushed aluminum finish on my raw Kirkham Cobra. It came out amazing after about 12 hours of work. They are definitely too harsh unless you want the brushed look.
Received 5,243 Likes
If it can be gotten to, a little permanent Sharpie on raised letters can be a God-send the next time a check is needed.
