Question
Old Jan 3, 2018 | 07:13 PM
kcoomes's Avatar
kcoomes
2nd Gear
Default Question
I have a 63 convertible. Why is the bottom rear corners of the doors so far off from the pillers in front of the wheel wells? They curve in almost 3/8 of an inch.
Old Jan 4, 2018 | 12:23 PM
64tux's Avatar
64tux
They weren't perfect from factory. Mine were way off till I did some body work to even them out. Adjusting door hinges might help.
Old Jan 4, 2018 | 12:26 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
There is an open thread about two below yours titled "door alignment."
Old Jan 4, 2018 | 12:30 PM
1snake's Avatar
1snake
To me, they were barely acceptable from the factory. I spend many hours correctly fitting factory panels and setting the gaps before I pick up my primer gun.
To Question
