1964 Corvette turn signal lever
Received 1,283 Likes
What is the location of the turn signal lever on others 64 Corvettes?
My lever seems to be very low. Sort of points to 8 o'clock position in neutral position. Drops to 7 o'clock position when dropped down for right turn.
The column housing has a notch for the turn signal wiring, which is at the bottom (6 o'clock position).
Received 6,946 Likes
2015 C2 of Year Finalist
In the neutral postion it is at the 9 o clock
Mine is a little above 9. Early 65 shown.
Also I assume you meant "pulled down for LEFT turn"
And here's a 65 I owned in 2005 that's a little below 9:
And another 65 I owned in 2011 at 9:
Here is a 65 that never had its column apart or out of car
Yes, I did mean pulled down for left turn.
Here is a diagram of what I am talking about. It is possible that I have the wrong steering column cone? Is there a difference in the cones between the various mid year cars?
Received 1,843 Likes
Turn signal lever on all '60s GM cars stands at attention at 9:00.
