[C2] Pulley question for borgeson/steeroids
Looking at manual steering C2's 327 base and HP for potential purchase.
Plan to convert to PS borgeson or steeroids
Vendors sell the power steering add on kit which includes the PS pump, bracketry and pump pulley. Isn't another pulley required at crankshaft to drive the PS pump?
Randy
PS Am I correct that if I get a 67 the Borgeson conversion is a little easier because I don't have to cut the shaft? Can 65-66 shafts be cut in the car or does column need to be removed?
Randy
Randy
Randy
Recent threads about Borgeson installation.
https://www.corvetteforum.com/forums/c1-and-c2-corvettes/4076218-borgeson-power-steering-conversion.html
https://www.corvetteforum.com/forums/c1-and-c2-corvettes/4080094-borgeson-power-steeing-pully-hits.html
66RBS (01-24-2018)
You are correct. Cut the shaft for 65 and 66. I bought a Borgeson kit for my 65 convertible 327/300. I would advise that you temporarily install the PS pump and figure out your pulley configuration as the supplied pulley with the kit did not line up with the CS pulley (for me). Also, it would appear that the supplied hoses are not exactly the correct length (for me). Another required mod (maybe) based on how you route the hoses to/from pump to box. Remember that the recommended caster for PS is 4-5 deg pos (Borgeson recommendation). Stock cross shafts might get you 3.5 deg max? Another mod to consider....
Never mind. Answer is in the links. Thanks Enfield Joe
