56- Engine install sequence pics
Old Jan 24, 2018 | 07:20 PM
Heath66's Avatar
Heath66
Default 56- Engine install sequence pics
Here are some pics of installing a fresh engine/trans into my 56 this past year.
Old Jan 24, 2018 | 07:30 PM
MidShark's Avatar
MidShark
Nice job!
Rich
Old Jan 24, 2018 | 07:35 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
And that's exactly how it's done! Nothing to it.
What model is that FI unit? I'm glad to see someone besides me has a 56 with FI.
Old Jan 26, 2018 | 02:46 AM
PattiR's Avatar
PattiR
Default engine and trans drop-in
Is that an 8 ft. ceiling in your shop?
Thanks,
Dennis
Old Jan 26, 2018 | 07:02 AM
61corv's Avatar
61corv
Chrome oil pan? Oh the humanity!
Great job and kudos for running fuelie.
Old Jan 29, 2018 | 11:10 PM
Jim Rosenthal's Avatar
Jim Rosenthal
Tremec TKO600?
Old Jan 30, 2018 | 01:12 AM
ptjsk's Avatar
ptjsk
Looks like it went just as it should!
Old Jan 30, 2018 | 10:33 AM
DZAUTO's Avatar
DZAUTO
Yes, we 56-7 folks with FI also like chrome--------------including oil pans!
Old Jan 30, 2018 | 10:49 AM
dmaxx3500's Avatar
dmaxx3500
cool ,thanks
Old Jan 30, 2018 | 06:29 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Heath;
Great looking power unit and car! Love it.
A couple of questions, if you please:
It looks like your tilter chain stays were tied into intake bolts threaded into your heads - is that right? I'll be doing mine shortly. If so, looks like the aftermost ones, and the ones just aft of the front intake runners?
If I may ask, is there something helpful for me (us) to know on why you selected those locations?
Also, it looks like you installed your power unit with the distributor installed - cool. I would like to install my power unit with the dizzy installed, too. Does that work okay?
Anyway, back to your regularly scheduled auto adoration, forum thread.
Did I mention, great car?
Old Jan 30, 2018 | 08:44 PM
DZAUTO's Avatar
DZAUTO
Originally Posted by Easy Rhino
Heath;
Yep, that's the way it looked to me also.
When I install engines, I usually have the exhaust manifolds installed and I use the outer corner ex manifold bolts.
This is the tired 350 we pulled out of my son's 73 and replaced with a 400.
Old Jan 30, 2018 | 08:59 PM
Easy Rhino's Avatar
Easy Rhino
DZ - that's a great shot - three generations?
Old Jan 30, 2018 | 09:23 PM
61corv's Avatar
61corv
Very cool car! I was joking about the chrome pan. After seeing everything else that is chrome, this must have been a show car in a previous life.
I love the traction masters, big brakes and the trailer hitch too! I have a set but don't like the way the look with the u bolt around the spring.
My oldest son help me install my engine and was a big help, my young watched how it is done on YouTube and told me what I did wrong... You are lucky man to have them around.
Easy Rhino- I used the exhaust bolts also. I slip some thin rubber hose over the chains. I had my injection, dizzy and fuel pump on also.
Old Jan 30, 2018 | 09:31 PM
DZAUTO's Avatar
DZAUTO
I'm taking the picture of two of my boys (red head has the 73) and a grandson.
This is the "replacement" 400 before we bolted up the TOTALLY rebuilt Turbo 400 to it. The intent was to duplicate the appearance of a 70-72 LT1 as much as possible-----------------but with 2 1/2in manifolds.
Old Jan 30, 2018 | 09:44 PM
Easy Rhino's Avatar
Easy Rhino
Nice!
Old Jan 30, 2018 | 11:39 PM
Heath66's Avatar
Heath66
Thanks on the compliments guys. I chose the intake mounting holes in the heads because my tilter just naturally fits there with little effort. The engine balances well there and it just works for me.
The distributor that was installed is my oil priming distributor with no teeth on the cam gear or upper components. I just chuck my 1/2" drill to it and spin it up to prime the oil system.
The FI unit is a 7320 that I rebuilt for this engine.
I got to admit, I love DZAuto's 56 and is one of my favorites.
Old Jan 31, 2018 | 10:49 AM
DZAUTO's Avatar
DZAUTO
Great minds think the alike. I also use an old dist for engine priming.
Old Jan 31, 2018 | 10:56 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
You made it look easy!
To 56- Engine install sequence pics
