c2 Rag Joint
Old Jan 29, 2018 | 07:32 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Originally Posted by Randy G.
Well, first of all it won't be numbers matching anymore.
What numbers are going to match?
Old Jan 29, 2018 | 10:00 PM
GTR1999's Avatar
GTR1999
Originally Posted by 63Corvette
There is NO comparison whatever in "FEEL" between my car and any street car. My tires are about a foot wide and sticky on "Fast" steer hole and VERY direct. It's a bear until it gets "up on its tiptoes"
Yes you're right, can't compare a road car to a street car. I would be interested to hear from those using them in a street application though.
Old Jan 30, 2018 | 01:54 AM
Randy G.'s Avatar
Randy G.
Exactly my point.
Old Jan 30, 2018 | 10:53 AM
65tripleblack's Avatar
65tripleblack
Drill out the rivets, throw away the rubber hockey puck/stops/horn ribbon, make a steel replacement, install it with 4 nuts/bolts, remove the lower column bearing (or let it disintegrate; you don't need one), and bolt in your new solid coupler. You can paint the steel disk semigloss black and have an artist paint some "nice" cotton threads on it for that "oreegional" look.
The car will handle like it has rack-and-pinion steering if you put the tie rod ends into the power steering position and refresh any worn tie rod ends, rebuild the link to the Pitman arm and adjust the lash in the steering box.
Old Jan 30, 2018 | 02:49 PM
JohnZ's Avatar
JohnZ
The rubber-puck "rebuild kits" are dangerous, kindergarten-engineered junk; buy a new replacement assembly and move on.
