Outer window seal replacement
Old Feb 12, 2018 | 10:04 PM
Bilmcna's Avatar
Bilmcna
Default Outer window seal replacement
I'm in the process of freshening up the 25 year old paint on my '63 roadster, and planning to replace the original weatherstripping.
While removing interior door panels today, I was sizing up the job of replacing the horizontal outer glass seal.
Will I have to remove the window mechanisms to get at the 4 little philips screws that seem to anchor the strip?
Thoughts or experiences?
Bill.
Old Feb 13, 2018 | 10:50 AM
RMBLROAR's Avatar
RMBLROAR
Bill.
You don't have to remove the mechanism, just remove the glass.....
Not a big deal....
Old Feb 13, 2018 | 09:50 PM
Bilmcna's Avatar
Bilmcna
Not a big deal....
Thanks Rmblroar, took another look today and thought the glass should lift out If I unbolted the 7/16" bolts at either end of channel, holes in door to provide access..
Also looks like the vent window and its post might not be to difficult?
Bill.
Old Feb 13, 2018 | 09:53 PM
RMBLROAR's Avatar
RMBLROAR
Bill.
You got it. The vent frame is a little tricky to remove but just take your time and snake it out of there. Again not a big deal.
Old Feb 16, 2018 | 09:52 PM
JohnZ's Avatar
JohnZ
The procedure is covered in detail in the "Corvette Body" section of the 1963 Corvette Shop Manual - you do have that, don't you?
Old Feb 17, 2018 | 07:39 AM
Bilmcna's Avatar
Bilmcna
I do have the '63 manual, and yes all of the glass came out as explained
The only "hang up" not mentioned in the guide was the little stop bumpers & brackets on the door glass that seemed to hang up the procedure a bit.
Wondering if the re-assembly could do without those little brackets, or if they could be re-attached after the glass panels were through the opening in the door? Will have to look at that.
Next challenge will be the 2 mechanisms, each of which have one rusted attachment screw of course.
Love that old GM manual, have been using the same one for 45 years, Back in the stone age before the magic of Forums, that little book certainly earned its keep for the hobby guy.
Its a bit "dog-eared" now, Patina they call it, right?
Especially like the facts that it was dedicated to just one car ( well 2 actually), so a minimum of flipping back and forth between models. Lots of detail for a first year model too.
Thanks GM.
To Outer window seal replacement
