[C2] engine install
Old Feb 17, 2018 | 11:12 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Default engine install
Can you install engine and trans with linkage on trans at same time c2?
Old Feb 17, 2018 | 11:25 AM
Joe Inama's Avatar
Joe Inama
Eng and trans yes, but no shifter or shifter mount
Old Feb 19, 2018 | 09:54 PM
59vetteman's Avatar
59vetteman
I wasn't able to get the engine and trans back into my wife's 67 with the fuel pump or LH motor mount on it. Had to remove both, along with the oil filter canister. Maybe, if I wasn't doing it by myself, it could have gone a little better!
Old Feb 19, 2018 | 10:06 PM
JRRHINO's Avatar
JRRHINO
Engine tranny and engine mounts no distributor starter fuel pump or linkage, put the rest on after. jack front of car up and have a cherry picker with a long boom. drop engine in at a steep angle and rotate flat when installing, so have a chain with adjustable threaded rod to rotate as needed ,worked great for me 8 times big and small block. just my opinion though.
To engine install
