[C1] '60 washer pump
Old Feb 28, 2018 | 05:50 AM
rrickerman's Avatar
rrickerman
Default '60 washer pump
How to determine if windshield washer pump is still functioning?
How to prime the washer pump?
Old Feb 28, 2018 | 06:18 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I did a lot of research on this a few years back. TriCo makes the pumps and is still around but they have no documentation on these old systems.
First item is the operation and minor troubleshooting.
We have the Nu-matic Hydrostatic version.
Second item is the US patent for the pump system...describing the operation if you can decipher the language.
File Type: pdf
File Type: pdf
Old Feb 28, 2018 | 08:45 AM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Post a picture to see if it is all there.
Old Feb 28, 2018 | 11:30 AM
Frankie the Fink
Army
The C1 washer systems were complicated and finicky.
A more recent model might be an option...but they are noisy and require a lot of upkeep...
Old Feb 28, 2018 | 04:44 PM
rrickerman's Avatar
rrickerman
Default washer pump
Would not mind going for a more recent model.
I have an assembly manual for my '60 but is hard to follow the hose hookups, thought I might have a hose incorrectly connected.
Is there a way to check if the pump is working, the vacuum canister and the wiper control ****?
Old Feb 28, 2018 | 04:48 PM
Frankie the Fink
Army
First, get a mouthful of water and with the washer nozzle hose unhooked at the pump, blow the water through the hose and it should squirt out both cowl nozzles - if so, then the system is clear, not clogged, no kinks or disconnected hoses. Verify the hoses are hooked up per the attached diagram.
Next check the valve on top of the vacuum tank; it should be one way...you can blow on it to check it.
Old Feb 28, 2018 | 07:34 PM
treh1's Avatar
treh1
Here's a good "how to" from Joe Calcagno:
http://www.rarecorvettes.com/RARE/Wi...r%20System.pdf
Old Feb 28, 2018 | 08:14 PM
Frankie the Fink
Army
Nice article. If forgotten about this one.
To '60 washer pump
