[C2] Blue interior paint code - 65 - Bright Blue paint code
Old Mar 4, 2018 | 09:05 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
Default Blue interior paint code - 65 - Bright Blue paint code
I have a 65 dash apart
The dash is a flat/satin blue
The covers are Bright Blue
Any know the paint code for the fiberglass dash
I am going to blast it and re-shoot it
Chris
Old Mar 4, 2018 | 10:10 AM
427 Sidepipes's Avatar
427 Sidepipes
Chris
Not sure if this helpz:
Old Mar 5, 2018 | 07:50 AM
csherman's Avatar
csherman
Thank you !!!!!
Old Mar 5, 2018 | 01:17 PM
NightshiftHD's Avatar
NightshiftHD
Chris
I would not blast that fiberglass dash (waterfall) Chris. It will create too much texture unless you're using soda. Just wipe it down with lacquer thinners (several times ... with different cloths each time) to ensure all ArmourAll and other contaminants are gone before painting.
Old Mar 5, 2018 | 01:31 PM
csherman's Avatar
csherman
Thank you !!!!
Appreciate the tip
I have not restored a dash waterfall before
Old Mar 20, 2018 | 06:52 PM
csherman's Avatar
csherman
All
Still having trouble with the bright blue interior paint
I mixed up a pint of the code above it is way too violet
Anyone have any luck with a PPG code or a WA number I can try?
Thanks in advance
Old Mar 20, 2018 | 07:04 PM
NightshiftHD
All
Thanks in advance
The easy way is just to buy either an aerosol ($20) or a quart ($80) of 65-67 Bright Blue interior dye from Corvette America or any of the multiple suppliers selling their stuff. Bill
Old Mar 20, 2018 | 09:10 PM
JohnZ's Avatar
JohnZ
Have you tried the PPG Color Librarian at (440) 572-6111? That number was good when I was painting my '57 in 1995.
Old Mar 20, 2018 | 11:00 PM
NightshiftHD
If John's PPG contact doesn't work Chris, the chart above does show the correct PPG/Ditzler code of the dash waterfall ... 3 Gloss (flat) - DIA-13071. If you can't find the recipe for PPG, here's a couple more ... BASF is 65V51R, and DuPont is 9223-LH which requires the addition of 2oz of DuPont 4528 flattening compound per pint of unreduced color.
For the 60 Gloss (semi-gloss) the PPG code is DL-13057. BASF is 66B29 and DuPont is 9271-LH and also requires 2ozz of DuPont 4528 per pint of unreduced color.
In my neck of the woods I have not found any PPG paint supplier that still lists DIA-13071 in order to show the mix recipe. The best I was able to do was to have them scan a radio side panel and attempt to mix based on that. But after 50+ years all original panels, even the ones like this that typically have limited sun exposure are much darker than they were originally. Keep us tuned as to how you make out. Cheers, Bill
Old Mar 21, 2018 | 09:32 AM
csherman's Avatar
csherman
Bill - Thank you
We will mix some up today and tomorrow
Old Mar 21, 2018 | 11:57 AM
Mike Geary's Avatar
Mike Geary
Default Gloss Reducer
Chris:
If the finish turns out glossier than you want, you can use Krylon Satin Clear acrylic to tone it down. Kinda hokey but it definitely works and hasn't yellowed after 10+ years.
FWIW I have always used the colored matched spray "dye" rather than pursuing a custom mix, since my paint dealers couldn't bring up the codes.
Mike
Old Mar 21, 2018 | 01:13 PM
csherman's Avatar
csherman
Thank you Mike
To Blue interior paint code - 65 - Bright Blue paint code
