[C2] Dashboard Extension Rods
Was looking around for info on removing the radio from my '66 when I happened upon a Corvettedennis YouTube video using dashboard extension rods to bring the dashboard forward. The are 5" or so threaded rods that replace the screws in your dash that allow you to move the dash in to help you get behind it. Has anyone seen these rods? Where can I get some?
Sal. (03-08-2018)
Sal. (03-08-2018)
Carriage bolts
I used 1/4-20 by 6" carriage bolts from Ace Hardware. Try Lowe's or Home Depot. Pull the seat out and add a pillow or foam in its place so you don't kill your back. Jerry
Sal. (03-08-2018)
Get one of those LED Coleman headlamp lights for working under the dash.
Although you're not really a Corvette 'guy' until you've been upside down in the footwell, both arms elbow deep in the dash wiring harness when that aluminum incandescent drop light housing rolls up against your cheek to the point you hear meat frying.
Real man stuff, that is...
Received 2,157 Likes
Take you seat out. It makes all the difference in slightly better contorting. Dennis
Sal. (03-08-2018)
Go buy a reasonable priced miner light. You know the headband with an adjustable led light. They are cheap and frees both of your hands. Amazing the light actually illluminates what you are looking at.
You shouldn't have to pull the dash out to remove your radio. Pull the center console left and right kick panels, Shift **** and the console trim plate section. I pulled my glove box out also. The radio is a tight fit. I just recently did mine. I wanted an upgraded radio and speaker. Hope this helps.
Rob_64-365 (03-09-2018)
The wiper **** has a set screw and a cut out in the bezel to access the set screw on the ****. I haven't pulled my headlight switch, but back in the day GM put a button on the backside of the headlight switch that you can push and the **** and shaft would pull out together, I believe this switch follows suite. Good luck.
Sal. (03-09-2018)
RAQ pretty much has it... Wiper switch is easy...the headlight switches do indeed have a small silver button on the bottom that you push to release the dash **** and shaft by pulling outward while depressing the button. Then you can unscrew the threaded ring using a tool designed for it, needle nose pliers (be CAREFUL they don't slip) or, if you work on waterproof watches, one of those tools to remove the back (as shown)...
Then just remove the electrical connector.
Sal. (03-09-2018)
That's pretty slick--I bought the tool from LIC to take off the ring--wasn't a lot and glad I had it.
Cruise-In III Veteran
SoCalErv & Sal.
You are right on about that "headlight LED". I picked this one up at Home Depot.
Yours truly looking for hair
I do have a related question in regards to pulling the cluster partially out. I've done this...years ago...so I've 'slept since I did this' Does that oil line to the gauge have enough slack (coiled) allowing you to move her out like I see in Frankie's pic? Thinking I may need to do this to replace all the bulbs with LED's.
Regards,
Jim
In God We Trust!
Regards,
Jim
In God We Trust!
