[C1] Adjustable temp wiring apprentice?
Old Mar 8, 2018 | 09:57 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Default Adjustable temp wiring apparatus?
I remember seeing it discussed but don't know how to search for it.
Old Mar 8, 2018 | 11:09 PM
65GGvert's Avatar
65GGvert
What exactly are you searching for? I don't understand "apprentice". Willcox has a tech article on their adjustable gauge if that is what you are looking for.
Old Mar 8, 2018 | 11:10 PM
54greg's Avatar
54greg
Check Corvette Central 57-78 temperature sender adjustable resistor variable.
Old Mar 8, 2018 | 11:38 PM
68hemi's Avatar
68hemi
Sorry, that was supposed to be apparatus. Unfortunately you cannot edit your title. It is some type of resister that you can add to the wiring of the gauge or to the sender
Old Mar 8, 2018 | 11:53 PM
65GGvert's Avatar
65GGvert
This is the one I mentioned. You might call then and ask if they have anything for the 57, if that is the car you are asking about.
https://willcoxcorvette.com/corvette...resistor-65-67
Old Mar 9, 2018 | 12:21 AM
68hemi's Avatar
68hemi
Thanks, yes I should’ve said 57
Old Mar 9, 2018 | 10:38 AM
Donald #31176's Avatar
Donald #31176
Cheapest thing is a volume switch from an electrical parts store that measures between 0 & 100 ohms.
Old Mar 9, 2018 | 11:02 AM
AZDoug's Avatar
AZDoug
2017 C1 of Year Finalist
Actually you can edit the title.
Go into edit, then I believe its advanced edit, or something similar will allow title mods.
Doug
Old Mar 9, 2018 | 11:28 AM
68hemi's Avatar
68hemi
Doug
Thanks Doug. I tried that but it only changes the title at the top of the first post but not the title that shows when surfing the forum, unless I missed something.
Old Mar 9, 2018 | 11:32 AM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
I have one on our 57. Easy install and set up.
To Adjustable temp wiring apprentice?
