The speedo on my 65 is 5mph too slow. Running a 22 tooth so need either a 21 or 20. But, in my research, they only make a 22, 23, & 24 in a large gear which I need. Why I don’t know, doesn’t make sense. Why would a manufacturer make two different sets of worm gears, a large and a small? And, if I’m correct, Borg-Warner did it and so did Muncie. Is it because of the seemingly endless combinations of axle ratios and tire sizes?
Other than reworking my tranny or speedo, is a ratio adapter my only option, and, if so, where can I get one that fits my car?
It's primarily the diameter change required on the driven gear as the number of teeth changes. As the number of teeth gets less, at some point they have to reduce the gear diameter to maintain tooth width and that requires a different spiral drive gear to compensate. Mopar dealt with this a little differently by using an offset speedometer drive housing that is rotated to different points to vary the distance of the driven gear center, to the spiral drive gear to compensate. Just two different approaches.
I think you may have to go to an adaptor but maybe someone else has another idea short of pulling the transmission tailhousing and replacing the drive gear.
Just in case you have not considered your axle ratio and tire size:
Yeah,that makes sense. I’m having trouble finding the adapter. Not sold by the repros?
I went all through this with my '56. Anyway, my notes say the GM part number is3860343 for a large 20 tooth. It's blue.
Edit: I did a few quick searches and it looks like it is unobtanium.
Yes, I agree, that looks like the correct part number I need. Thanks much! Now to find it!
