1960 window HELP!
Old Mar 19, 2018 | 10:18 AM
Captain Bud's Avatar
Captain Bud
2020 C1 of the Year Finalist - Unmodified
Default 1960 window HELP!
Situation...The car has power windows. I went to lower the drivers window and it came down in the rear but the front of the window came down about half way. I removed the metal panel on the door and looked in with a mirror and light but don't know what I'm looking for. I'm hoping I don't need to remove the window. Any suggestions?
Thanks, Bud
Old Mar 19, 2018 | 10:30 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Most times the window will hang up on the window stops when this happens. Occasionally the door garnish at the front of the window at the bend will roll up against the glass and bind things up. I’m not home so I can’t post pictures right now.
Old Mar 19, 2018 | 11:11 AM
Captain Bud
Default Window help
When I lower the window, the rear goes all the way down and the front hangs up about half but a hear a load clunk when it hits whatever is in the way. If both the and back of the glass came down evenly until the halfway point then just the rear part of the glass continued retracting, I would think it’s hanging up on something. But, as soon as I lower the window, the rear of the glass drops faster than the front. If it means anything, when I raise the window, the back comes up even with the front the the entire window goes up normally.
Old Mar 19, 2018 | 11:18 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
There are two rollers taht go into the metal window channel the glass sits in.
You need to verify both rollers are in the channel, and are actually round, and not broken
The rollers are white nylon, and one is on the end of each arm of the window raiser.
Doug
Old Mar 19, 2018 | 11:21 AM
Captain Bud
Default Window
That’s what I’m thinking. Getting in there seems almost impossible with my hand though
Old Mar 19, 2018 | 12:06 PM
Frankie the Fink
Army
With the door panel off you can remove the access plates and look around inside to diagnose the problem. That difference between the front and rear of the window when it blinds makes me think Doug is right. Something has come loose.
Old Mar 19, 2018 | 12:50 PM
AZDoug's Avatar
AZDoug
With the window most of the way up, they is plenty of arm room.
Doug
Old Mar 19, 2018 | 04:01 PM
Captain Bud
Default Window
Worked. All fixed. Thanks Doug!
Old Mar 19, 2018 | 04:58 PM
Frankie the Fink
Army
After you fix enough of these types of PW problems you'll learn to 'bump' the window switch lightly as it approaches its upper or lower full travel. Driving the window full speed in either direction to the limit can cause the funky C1 window configuration to screw up in a variety of ways...window stops and garnishes are favorite snag points...
Old Mar 19, 2018 | 05:03 PM
Captain Bud
Frank, both you and Doug we right on the money. All fixed except I screwed putting the door panel back on. I fixed all the holes with sheet metal and that worked great except I didn't position the panel correctly before I drilled holes in the sheet metal. No big deal, just drill out the pop rivets and put on new sheet metal pieces. Thanks again, Bud
Old Mar 19, 2018 | 06:16 PM
Frankie the Fink
Army
That's great. As I said (and you can see here) the SPW power window conversion is FAST, nothing like an original setup. So things can get a bit dicey if you rocket them up and down as fast as they'll go, as far as they will go...the window hardware is simply not configured to deal with it!
I'm actually runnin' 'em a little too fast (not 'bumping' the switch) at the limits in this video:
To 1960 window HELP!
