I haven't had any experience with the Corvette kit sold by Auto City Classic, but I got one of their 69 Camaro kits for a customer, and he was very happy with both the installation and operation of the kit.
I bought a mix of new (conduits, wiring) and used (regulators, motors) or NOS (console switches) parts to put PW in my 67. I had the motors rebuilt, of course. The nerve-wracking part is cutting the slots in the door posts for the conduits; measure eleven times, cut once, then enlarge the holes with files. I always prefer to use factory-designed parts, rather than aftermarket kits. In case something goes wrong down the road, I can look up the factory system in the assembly manual.
I added PW to my '61 Vette using an AutoCity PW kit and added PW to my 65 Coupe with a used set from a '63 Vette. Both require a fair amount of work but the midyear install was much easier since that forward conduit slot in the door jamb is basically a template because once you drill that little dimple out, the steel backing plate already has the required oval opening on all models whether it was going to get a factory PW set up or not so it's a matter of routing out the hole using that slot as your template. A friend once mentioned you can tell a factory job from a hobbyists installation because when the guys on the assembly line opened up the holes, it wasn't always a nice neat job.
Mike T - Prescott AZ
I just bought the electric window kit for my 65. I will be installing it soon.
Looks straight forward. However, as a PP said cutting the holes is nerve wracking. A friend of mine made a special tool to cut the hole int he door without taking it off. Also, cutting the square hole int he console is very nerve wracking. I'll let you know how it goes.
Your comment reminds me that I took my console and switches to an automotive machine shop and had them cut the rectangular hole. THAT saved a lot of angst.
That is probably a good way to go. It can be a very stressful operation .
