I don't know which car you're working on, but my 65 regulator has a ground wire run to the case under the screw, and it bolts to a fiberglass fender, so I'll say no.
If your asking about C2s, the voltage regulator mounts to the inner fender (fiberglass), so the VR is not grounded by the mounting. Thus the separate black ground wire to the VR to provide a ground.
The mechanical voltage regulator is what is called a "vibrating points" device...the points can actually open/close 200 times/second. The rubber isolators are to dampen any external vibrations that could affect the V/R operation... They are not electrical insulators...
An advantage of the solid state V/Rs like the Wells VR-715 is that they don't give a hoot about vibrations. You could lag bolt them onto a cylinder head...
Sorry I forgot to say that it was for my 65. So it mounts on the inner fiberglass? I've tried to find a matching bolt pattern, on the fiberglass, but didn't see one. I'll try looking again soon. Guess it would help if I looked in the AIM manual for placement. Bubba may have filled it in. Lord knows he did a number to the headlight opening.
The black wire and the rubber coated nuts had me wondering, so that's why I posted this message.
Thanks Frankie! I bolted mine down then started looking through the parts books when I saw the rubber coated nuts. I knew I was doing something wrong. This is another lesson learned!
Thanks,
Dex.
Dex, I owned an unmolested 65 coupe with a/c and t/i and it had a delco transistor voltage regulator that was mounted on the left (drivers) side of the core support on the "engine side" of that support.
Thanks for the picture 65GGvert. I probably over looked the holes, but the front end was hit, so Bubba may have filled them in.
Thanks,
Dex.
Factory air cars always have the regulator on the driver side due to AC compressor and alternator locations. For 1965 small block non-air cars, I believe the regulator is on the right inner fender as alternator is on this same side.
Thanks C.W.C.. My car is a non-A/C car and the wiring comes in on the passenger's side. I just went and looked at the area the AIM said it was supposed to mount in and there's no holes. It's also an area that had some work done....so the holes were filled in. Well, nothing like drilling new holes.
The AIM is your friend.
Larry
Yep, the AIM is my friend. It shows where the VR supposed to be mounted but the holes were filled in.
Thanks,
Dex.
Sorry, it's been a lot of years since I owned a non-a/c car. Even the one I have now with Classic Auto Air has had the alternator and regulator moved to the driver's side. I forgot about that change.
My crate engine has the alternator on the driver's side, so I had to buy an alternator relocation harness. I did see, in some older posts, that 64 corvettes had the regulator mounted on the radiator support, driver's side. I'm sure it doesn't really matter if it's mounted to the radiator support or the fiberglass inner fender, as long as it's grounded.
