Build Dates
Old Mar 26, 2018 | 08:47 PM
PreviousOwner's Avatar
PreviousOwner
Default Build Dates
Question for the masses and showing my lack of knowledge:
What's the odds of the Body Build Date and the Engine Build Date being exactly the same date? Guess it happens, ...just don't think I'd ever run across it before.
TIA,
PO
Old Mar 26, 2018 | 09:23 PM
65GGvert's Avatar
65GGvert
AOS body or St Louis? If the body was built at AOS and the engine at Flint and both shipped to St Louis for assembly, I can think of a scenario. Is the vin birthday a little later?
Old Mar 26, 2018 | 09:35 PM
PreviousOwner
St. Louis - Assembly date 12 days later. All seems to time out right, just found it a little strange. Maybe not?
BTW, thanks for your electrical help a couple of years back. Had to go with a new wiring harness. Just too much corrosion in too many places.
Old Mar 26, 2018 | 10:17 PM
65GGvert's Avatar
65GGvert
No problem, I hope that means you got it all worked out.
Old Mar 26, 2018 | 10:50 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Entirely plausible.
My '65's has a final assembly date of 1 June, 1965, with an AOS body built on May 19th, 1965. The original engine is missing, but could have easily have been assembled at Flint on 19 May as well.
I'm building a 327 with a May 14th engine assembly date, with a May 13th, last hour of second shift casting date.
To Build Dates
